Time to finish
- oldblighty
Time to finish
03 Nov 2017 14:45 - 09 Nov 2017 16:26
Hello to everyone on KZRider just become a member
Have an old z400 which I got many years ago which came as a pile of parts the previous owner had took it apart what I mean is he had taken apart everything that could be taken apart including the engine then lost interest when I got it home on closer inspection found many parts had either had it or what should be present wasn't so decided to make a bobber I nearly got it finished then put a cover over the bike for the next 4 years until recently dragged the bike out and intend to get it finished this is my first bobber build and most parts are Kawasaki which has been altered in one way or the other to fit the build .
Last edit: 09 Nov 2017 16:26 by KZQ. Reason: Duplicate picture
Re: Time to finish
03 Nov 2017 15:10
Welcome to the KZR forum.
A very unique bobber build, keep on posting your progress with a lot of pics.
- jayrodoh
Re: Time to finish
03 Nov 2017 17:23
That's a beautiful bobber! IMHO bobbers either turn out fantastic or horribly wrong, yours definitely looks great.
1982 KZ750-M1 CSR
- mopguy
Re: Time to finish
03 Nov 2017 17:30
Nice.
- les holt
Re: Time to finish
04 Nov 2017 06:09
Nailed it! That's as nice of one I've seen.
Les Holt
PDM
Les Holt
PDM
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
Re: Time to finish
04 Nov 2017 07:55oldblighty wrote: .........Have an old z400 which I got many years ago which came as a pile of parts the previous owner had took it apart what I mean is he had taken apart everything that could be taken apart including the engine then lost interest ....................
I'm happy to see you were able to build a bike out of a pile of parts. Congrats! I always find it amazing that folks will totally disassemble a bike and then lose interest. The bike below is just one example. The owner took apart a perfectly good bike because he was going to clean up every part and then reassemble. Of course, after breaking the bike into a million pieces he lost interest and did not reassemble. Ed
- oldblighty
Re: Time to finish
04 Nov 2017 10:16
Yes it is so easy to get out the spanners and start dissembling and before you know it your facing a major task of putting it all back together maybe some set out with good intentions but become overwhelmed with the task ahead then the interest is lost.
- oldblighty
Re: Time to finish
04 Nov 2017 10:40
Thankyou I put in a 2" stretch to the frame with a 1" drop which worked out just right for my height 5' 7"
- riturbo
Re: Time to finish
06 Nov 2017 17:17
Nice job looks great
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
- oldblighty
Re: Time to finish
07 Nov 2017 10:31
Hi thanks
Just got the wiring finished with the main loom running inside the frame which looks a lot tidier than having it on the outside glad to find all circuits function as they should after connecting up a car battery as I decided on a battery less ignition setup but still carbs or carb to fit and dial in but haven't decided on which way to go yet.
- azman857
Re: Time to finish
08 Nov 2017 22:13
Oldblighty, You have one of the better looking bobbers I've seen. It's begging to be on the road! Finnish her and show her off!
- oldblighty
Re: Time to finish
09 Nov 2017 04:53 - 09 Nov 2017 08:39Attachment not found
Last edit: 09 Nov 2017 08:39 by oldblighty.
