Beginner Rider w/ Black 82' KZ1100
Re: Beginner Rider w/ Black 82' KZ1100
28 May 2017 14:31Rogan81 wrote: Help please!!
How do drain the fuel tank on a kz1000? Do I need a vacuum pump?
I've pulled the fuel line and put the petcock on reserve but the fuel won't drain. I'm new and trying to figure this out.
Thanks
Try putting the petcock handle in the "RES" or PRI" position rather than in the "ON" position you show in your photo. Ed
- Rogan81
28 May 2017 14:38
I put the petcock on reserve. Maybe I pulled the wrong line. Any insight? Nothing in here he owners manual aboutdraining the tank. Thanks
28 May 2017 14:40
The fuel line is the one that goes to the "T" down between the carbs. The vacuum line typically just goes to the #2 carb toward the front of the carb. Also, try putting the petcock on "PRI". Fuel should flow. Ed
28 May 2017 15:10
As 650Ed wrote, PRI is the position to drain the tank or prime the carburetors after they are reinstalled. That is a vacuum operated fuel valve. When the engine is running, fuel should flow from either RUN or RES. Normally, it should be in the RUN position. When the fuel level in the tank gets down to a certain level ( about 1.5 or less gallons left) the engine will sputter a bit, then you should move the lever to RES and start looking for a gas station. When you fill the tank up, move the lever back to RUN and repeat.
Don't neglect to install a good inline fuel filter after you drain and refill the tank. Be sure the filter is designed for a gravity feed (no fuel pump) system.
- Rogan81
28 May 2017 15:57
Thanks guys. Do I need to remove the tank to pull that enter fuel line?
28 May 2017 19:13
You can, or you can remove the fuel line from the petcock and simply replace it temporarily with a long line that will reach the gas can you are draining fuel into. Ed
- Rogan81
Re: Beginner Rider w/ Black 82' KZ1100 LTD
19 Jun 2017 10:54
I'm looking for a little help. I recently changed the oil and may have overfilled a bit. The bike turns over and will occasionally run idle for a few seconds and then shut down. I hold the electric start button down for about 10 seconds and sometimes it starts but when I go to throttle it shuts down. Will overfilling the oil cause this problem? Any ideas?
Thank you in advance.
19 Jun 2017 11:44
Instead of taking a chance on damaging something I HIGHLY recommend you simply remove the excess oil. It is extremely simple to do; just run a small clear plastic tube down into the oil filler hole and siphon some out. Then ensure the oil level is correct by looking at the site gauge on the right side of the engine. Ed
- Rogan81
19 Jun 2017 12:22
Thanks Ed. I'll do that this afternoon.
19 Jun 2017 16:21
How much is a little?
- Nebr_Rex
19 Jun 2017 17:14Rogan81 wrote: Here's some pics. It's still a little dirty but I just realized it's actually a RTD1000 (european version of the KZ1000).
Can you tell me if its ok to these carburetors in a dip basket overnight to clean?
Where do you get RTD1000?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- tthunderdan
20 Jun 2017 00:20
Cool old bike. I rode/owned nothing but Yamaha singles, enduros with the newest being an '81 XT500 (which I just sold recently, regretfully). I just got an '83 KZ1100A and I love it. To have a bike with disc brakes, 12V electric start and blinkers you can see in the daytime is the shit for me. Having about 80 more horsepower on tap than anything I've ever had is nice also. The KZ remains somewhat intimidating to me, mainly wheeling it around and manuvering at stops (the fold up footpegs helps me here), but feels perfectly natural once rolling along. I also get a good bit of attention when we stop, seems alot of guys had KZ's back in the day, and they gotta' tell me about the time...I think the big KZ is gonna' stay around awhile. I wouldn't sell it for 2X what I paid. About 0-80 mph is where the fun is for me, a guarenteed smile... there sure is alot of cool old big jap bikes on CL lately for a grand or two, if only I had a bit of trumps money, HA
Dan from Slippery Rock PA,
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
