My 1st motorcycle: 1976 KZ900
- 9er rider
- Keep a cool tool
Re: My 1st motorcycle: 1976 KZ900
07 Mar 2017 09:38
A guy on here once said "Ride like your invisible and NO One can see you"
- Barry2
07 Mar 2017 09:42
A KZ900 is not the quickest or the most fast out there anymore but it's plenty quick enough to put you into the hospital or worse if you don't give it plenty of respect. Be careful and enjoy.
1976 KZ900
The following user(s) said Thank You: Conspiracy
- stokes
07 Mar 2017 10:13
Real nice bike.It is big for a learner,but if you keep within your skill level for the first couple hundred miles you'll get used to it.Just go easy on that throttle.
1980 KZ1000B Ltd
The following user(s) said Thank You: GPz550D1, Conspiracy
- Conspiracy
07 Mar 2017 10:43stokes wrote: Real nice bike.It is big for a learner,but if you keep within your skill level for the first couple hundred miles you'll get used to it.Just go easy on that throttle.
I haven't found a need to go much past 1/4 - 1/3 throttle. That gets me up to speed quick enough.
Novice rider
1976 KZ900
1976 KZ900
07 Mar 2017 11:16
- Conspiracy
07 Mar 2017 12:16
I have a thread open in the carburetor section.
www.kzrider.com/forum/3-carburetor/60530...rb-re-jet-and-tuning
So it seems there are several versions of the z1 carbs? How can I tell which one I have?
I searched jetsrus.com for part numbers and came up with the same main jet 04/042 but a different pilot jet vm22/210. I believe I have 117.5 main and 15 pilot in the carbs now but those don't line up with what seems like came in the stock z1 carbs. I believe I am running lean and would want to increase jets to 120/20.
My mechanic says that a lot of the gaskets are worn out as well. You're saying I should just buy those separate? My local dealership says they can order rebuild kits for the z1 carb. Why would you suggest against this?
Novice rider
1976 KZ900
1976 KZ900
- slmjim+Z1BEBE
07 Mar 2017 14:31
From the pics it appears that your carbs are the later ones, from the late '74 Z-1A's / '75 Z-1B's. They have small drain screws in the float bowls that face the sides instead of the large drain plugs that face straight down as on the '73 Z-1's / early '74 Z-1A's.
The ID mark for the later carbs is 2170, stamped on each outlet flange.
Stock jetting was:
Main - 112.5
Pilot - 17.5
Float bowl gaskets begin to weep with age. We'd suggest ordering rebuild kits from Z1 Enterprises or Z1 Parts.
Can't help you on jetting for pods. We run stock air boxes on all of our Z-1's.
Good Ridin'
slmjim & Z1BEBE
Stock jetting was:
Main - 112.5
Pilot - 17.5
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- spdygon
07 Mar 2017 19:03
By the pictures looks like you have a Z1 900....74-75 model . What are the engine and frame numbers ?
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
- Conspiracy
07 Mar 2017 20:49
Apparently I have a Frankenstein hybrid, not sure if that is good or bad...
The frame is Z1F-505022
The engine is Z1E-085345
Novice rider
1976 KZ900
1976 KZ900
- KZJOE900
- Administrator
Super Users
07 Mar 2017 23:25
According to Zedder.com you have :
1976 KZ900-A4 Frame
1975 Z1-B 900 Engine
Carbs probably came wiith the 75 engine.
1976 KZ900-A4 Frame
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
08 Mar 2017 04:24
Are the numbers close enough that this could be a factory oddity? Say there was a Z1 engine or two still in the pipeline when the KZ frames went into production? Not likely I know, but stranger things have happened.
- slmjim+Z1BEBE
08 Mar 2017 05:46Conspiracy wrote: Apparently I have a Frankenstein hybrid, not sure if that is good or bad...
Neither good nor bad. Frankenbikes are not uncommon. The Z-1 and KZ900 motors are identical for all practical purposes. The only people who would care would be collectors wanting correct numbers.
Good Ridin'
slmjim & Z1BEBE
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
