new member with a kz550ltd
- cbrianroll
05 Jan 2017 08:14 - 05 Jan 2017 08:24Attachment 20161222_172525.jpg not found
Her it is as I got it...
And now....
Attachment 20170104_170644.jpg not found
15000 miles ish, no spark on 2 and 3, got an eBay igniter coming, gonna bare bones rewire, make a cafe Ish, brat thingy. This is my first kawasaki so I imagine I'll have a few questions from you guys.
1980 kz550ltd
Last edit: 05 Jan 2017 08:24 by cbrianroll.
- loudhvx
Re: new member with a kz550ltd
05 Jan 2017 09:13
Looks like you got your hands full!
In my signature there are a bunch of links you may be interested in.
One is for the carburetors.
One has several service manuals you probably should download. Grab all of them to have several references.
And you should read the valve train warning before removing the valve cover.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
05 Jan 2017 10:59 - 05 Jan 2017 11:34
The problem with 2-3 could be the ignition coil that fires those two cylinders.
Last edit: 05 Jan 2017 11:34 by martin_csr.
- cbrianroll
05 Jan 2017 11:22
Thank you both, I switched coils to check, and if I tested all the wiring it pointed to igniter. I've already lurked a bit, I had problems joining, I have a manual, but I did download your links already! My major problem is troubleshooting.....I'm not very good with electronics yet.
1980 kz550ltd
05 Jan 2017 11:27 - 05 Jan 2017 11:33
Okay. Then I was going to suggest it could be one of the pulsing coil pickups, but you've probably already checked.
Last edit: 05 Jan 2017 11:33 by martin_csr.
- cbrianroll
05 Jan 2017 12:17
We'll find out in a day or two once I get the igniter. I have been wrong before LOL
1980 kz550ltd
- cbrianroll
07 Jan 2017 14:33
Well.....yup.....rookie mistake. Is indeed looking like the pick up coil, blue and black good....yellow and red nothing, the wires are pulled out a little also so I tested it there also.....dead. oh well, live and learn bwaa ha ha. Still not sure how I missed that.
Attachment 20170107_143827.jpg not found
1980 kz550ltd
- loudhvx
07 Jan 2017 16:09
You can use pickups from any KZ as long as the actual pickup itself looks the same as what you have.
You can also use a black/blue pickup in place of the red/yellow. You just have to re-route the wires and probably make them longer. The black wire swaps in place of yellow, and blue swaps in place of red.
Here's a link, for reference, in case you take apart the timing plate to swap the pickups.
gpzweb.s3-website-us-east-1.amazonaws.co.../PickupAndRotor.html
1981 KZ550 D1 gpz.
Other links.
Other links.
- cbrianroll
07 Jan 2017 18:45
Cool beans man! Thanks, I have yet to search for a replacement. Did however start assembling the carbs and painted the motor while I was sonic cleaning the parts.
1980 kz550ltd
