Introducing myself - 76 Kz 900
- Kz900Pablo
01 Jul 2016 17:46 - 01 Jul 2016 19:16Attachment IMG_0657(1024x768).jpg not found
Hi everybody. Paul Menten here. I just purchased a 76 KZ 900.
1976 KZ 900
1972 H1
1972 H1
Last edit: 01 Jul 2016 19:16 by Kz900Pablo.
Re: Introducing myself - 76 Kz 900
01 Jul 2016 17:50 - 02 Jul 2016 05:31
Welcome. Nice bike.
Last edit: 02 Jul 2016 05:31 by SWest.
The following user(s) said Thank You: Kz900Pablo
01 Jul 2016 19:28
Nice looking ride.
Welcome to the asylum :silly:
02 Jul 2016 05:21
Welcome Paul
Nice 900
Nice 900
- KZJOE900
- Administrator
Super Users
02 Jul 2016 07:14
Awesome find! Looks like an original survivor. Is it in running condition? Looks like a Kerker on there. If you want to maintain the bike's value and increase it, I would keep it original. And maybe get an original style seat. Even the original paint makes it more valuable if it is in decent shape. It still won't have the original exhaust (which are pretty pricey) but it will be close. Good luck with whatever you decide to do with it.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
02 Jul 2016 14:37 - 02 Jul 2016 14:44
Nice bike! Welcome aboard!
Here are some tips that you may find helpful:
Many newbies and not so newbies run into or issues with their bikes which could be easily avoided with a little preparation or information. Here are a couple recommendations that I hope you will find useful.
Before riding your KZ you should take a little time to become familiar with it. Simple things like checking the oil, tire pressures, etc. are explained in the Kawasaki Owner's Manual. If you bike didn't come with one (they normally are in a little holder on the bottom of the seat) you can usually find one on eBay - be sure to get one for your exact year/model.
MANUAL
You really should consider buying the Kawasaki Factory Service Manual for your bike. The factory service manual provides instructions on the various maintenance procedures and schedules for your bike, procedures for diagnosing problems, proper torque values for the various fasteners (VERY IMPORTANT), and insight into how each system on your bike works even if you are not repairing that system. Studying the manual before you attempt performing service on your bike will impart an understanding of the system you are working on which will increase the odds of success.
The manuals usually are readily available for most models on eBay and other sources; but be sure to get one that has your specific year and model in it as there are differences between the various KZ650 models. I do not recommend Clymers, Haynes, or other aftermarket manuals as I have seen instances where they provide inaccurate advice. You may decide to use those to supplement the factory manual, but in my opinion they are not a suitable substitute. If you have trouble finding one for your model ask us to help.
TOOLS
WARNING! Do not even try to use Phillips screwdrivers on the Kawasaki cross head screws. Despite their appearance they are not Phillips screws. They are Japanese Industrial Standard (JIS) screws. The tips of Phillips screwdrivers are too long & pointed to allow the 4 blades of the screwdriver to properly engage the screws, so when you apply force the screw head slots will deform and look like crap. The fact is that Phillips screws were deliberately designed to have the screwdriver bit "cam out." This was done to prevent production line assembly from over-tightening, stripping, or breaking the screws. JIS screws do not have this problem. A proper fitting JIS bit can tighten a JIS screw to and beyond the torque spec without camming out. Here's the good news - you can easily modify standard Phillips screwdriver tips to fit the JIS screws.
I have ground down the tips of DeWalt #2 and DeWalt #3 Phillips to make them fit JIS screws. The large crosshead screws on the cases take modified #3 bits (or genuine #3 JIS bits). To modify the DeWalt bits you need to grind the very tip a little, then test fit, then grind a little more and test fit, etc. until the bit no longer "rocks" back and forth in the screwhead. Picture 1 below shows how a DeWalt #3 bit fits the case screws of my KZ650 after being ground properly. The #2 DeWalt bits can be modified the same way to fit smaller JIS screws. Pictures 2 and 3 below shows DeWalt #2 and #3 modified bits.
I did find a place that sells authentic JIS bits. They don't list the #3 bit, but if you contact them they can provide the #3 JIS bits even though they are not listed on the website. These folks were very easy to work with, and the authentic bits do work great. Here's their site:
www.rjrcooltools.com/shop_item_detail.cfm?subcat_ID=89
Pictures 4 & 5 below show a comparison between my home made modified bits with the authentic JIS bits, and picture 6 shows a comparison between Philips and JIS bit tips.
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
PICTURE 6
Before reaching for that wrench or ratchet consider the following. The bolts are steel, but your engine and front forks are aluminum. The bolts are much tougher than the aluminum and if over tightened will strip the aluminum threads. Although these can be repaired, preventing damage by applying proper torque will save you grief, time, and money. Tightening fasteners properly requires torque wrenches. Various vendors, including Snap-on, CDI, Sears, etc., market torque wrenches. The two most popular types are the bar type and micrometer type. Either will work, but the micrometer type is a bit easier to use, especially if you are tightening several fasteners with the same torque - such as cylinder head covers. You will need a torque wrench calibrated in INCH POUNDS for many of the bolts. You will also need a torque wrench calibrated in FOOT POUNDS for the larger bolts. Don't try to use the foot pounds wrench on the smaller bolts as it will not be sensitive enough at low torque settings to provide accurate torque. There are many fasteners that require low torque. These include such things as 6mm oil pan bolts, cylinder head cover bolts, etc. for which the torque in 61-78 inch pounds. These low torque bolts require a wrench that is accurate at low settings and this wrench should be graduated in inch pounds. In addition, there are numerous high torque fasteners such as the front axle nuts (51 - 65 foot pounds) or swing arm pivot shaft nuts (58 - 87 foot pounds). These require a wrench that is accurate at higher settings; this wrench should be graduated in foot pounds. Using the proper torque wrenches to correctly tighten fasteners will help prevent damage and contribute to a safe bike. The Kawasaki Service Manual will list the various torque specs for the bolts. I suggest you get the manual before buying the torque wrenches so you can decide which wrenches best meet the torque specs.
Consider buying a can of Kroil penetrating oil and use it to soak stubborn fasteners for a couple days before trying to loosen them. Remember, the original screws and bolts were installed on your bike when Jimmy Carter was President, so many of them may be hard to remove. Kroil can be bought online, at guns shows, and at some other venues.
MOTOR OIL
The ingredients in oils have changed over the years. For example, today's Castrol GTX oil (and pretty much all other AUTOMOBILE oil) is not the same as it was in the 1980's. Back then it worked great in KZ bikes. But, things have changed. Early AUTOMOBILE oils contained zinc phosphorus compounds (ZDDP) to protect engine components from metal to metal contact. This was good for engines, but it was found to be destructive to catalytic converters. Consequently, in AUTOMOBILE oils ZDDP was virtually eliminated and replaced with different chemistry generically referred to as "Friction Modifiers." These work fine and offer good protection for normal AUTOMOBILE engines. However, today's AUTOMOBILE oil "Friction Modifiers" are destructive to wet clutches. KZ bikes (and many other brands) have wet clutches. As a result of these oil chemistry changes a distinction needed to be made between those oils which are suitable for wet clutches and those which are not. That distinction was documented by the Japanese Engine Oil Standards Implementation Panel (JASO). JASO developed a number of different oil specifications for different applications. The specifications that apply to 4 stroke motorcycles fall under the "4T Specifications." Within the 4T specifications the JASO MA class oils are specifically formulated for 4 stroke motorcycles with wet clutches.
There are synthetic, semi-synthetic, and non-synthetic oils that meet the JASO-MA standard and any of them will work ok. However, using oils that are not designated as meeting the JASO-MA standard is destructive to KZ clutches.
Good luck with your bike. Ed
MANUAL
TOOLS
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
PICTURE 6
MOTOR OIL
Last edit: 02 Jul 2016 14:44 by 650ed.
02 Jul 2016 17:03
- 9er rider
- Keep a cool tool
02 Jul 2016 17:25
What an excellent looking motorcycle man! what kind of miles are on the clicker? Ive ridden the Puget Sound and the coast a couple years. I lived out side of Gig Harbor, and have cruised the Columbia River.Nice cruising.
- missionkz
04 Jul 2016 19:58
I've often wondered if I ruined the value of my 77' KZ1000A by removing everyone of those bastard JIS screws on my bike and replaced them with stainless steel Allen head screws....
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
04 Jul 2016 20:17
To a purest I guess so but to someone that wants to ride, it's a big PLUS.
- Kz900Pablo
05 Jul 2016 11:03
@KZJoe900, Thanks, I feel very lucky to have found this bike. It has 21000 miles and it is mostly original, it's a survivor. It has been garage kept since 1976. Yes, that's a Kerker exhaust pipe in perfect condition. There are some scratches and one dent in the tank that's small but includes a gouge in the paint. The engine covers don't have rashes thanks to what I think are called 'case savers'. The tires are the original Avon tires! Clearly they will need replacement.
It runs well enough. I think a carb bowl is leaking because it's leaving a gas stain under the engine if I leave the petcock open when parked.. The bike feels nervous at freeway speeds. I'm guessing that the swingarm and front fork bearings need attention, and new tires will help the cause.
It's going to stay as-is for now. I'll service it and make it road-ready. I'm guessing it will end up in Arizona with my brother but I'm going to have some summer fun with it for now.
1976 KZ 900
1972 H1
1972 H1
- Kz900Pablo
05 Jul 2016 11:159er rider wrote: What an excellent looking motorcycle man! what kind of miles are on the clicker? Ive ridden the Puget Sound and the coast a couple years. I lived out side of Gig Harbor, and have cruised the Columbia River.Nice cruising.
Hey, right back at 'cha, nice bike! You have two of these beauties. The dark green paint is my favorite color. The bike has 21000 miles.
You might be able to help confirm something I read about the '76 Kz 900 - the tube frames have thicker wall pipes in their construction than the prior years?
1976 KZ 900
1972 H1
1972 H1
