Seat change and sissy bar.
  • ChristineC
  • ChristineC's Avatar Topic Author
05 Apr 2016 08:39
#719367
Hi! I am a new owner of a 1980 KZ750 LTD. I want to change the seat and ordered one on eBay. the slots for the pins don't line up under the seat. I think it's because the set I bought is for a spectre. Is there anything I can do? I added a photo of the new seat sitting on the frame. It looks good but doesn't fit underneath.
Also, I want to get a sissy bar and luggage rack, any tips about buying those (sizing)?
  • mopguy
  • mopguy's Avatar
Re: Seat change and sissy bar.
05 Apr 2016 08:53
#719368
I have the same bike and it came with a two piece seat, if you look in the picture gallery here you can see what they look like.
The following user(s) said Thank You: ChristineC
  • ChristineC
05 Apr 2016 08:56
#719371
So I have to buy a two piece seat? When i look on eBay they're listed as 1980 KZ 750 seats. I figured I had options.
  • mopguy
  • mopguy's Avatar
05 Apr 2016 09:11 - 05 Apr 2016 09:13
#719375
Yes and if you look in E-bay , they either sell them as a set or separately. You can ask in the wanted section here, maybe someone has a spare., or you are going to need to modify the bottom of your seat in order to be able to attach it.
Last edit: 05 Apr 2016 09:13 by mopguy.
  • martin_csr
  • martin_csr's Avatar
05 Apr 2016 09:15 - 05 Apr 2016 09:24
#719376
For direct fit. 80-83 KZ750-H Ltd. 81-83 KZ650-CSR. the csr seat is 1-piece as are some of the Ltd H seats.
I put an 82 750-Ltd seat on my 81 650-CSR. and recovered it w a Travelcade saddle skins seat cover.
For a luggage rack & sissy bar, there are universal fit K&G combos from back in the day available on eebbaayy. they can be listed in all sorts of ways, often times depending upon what bike they were on. KZs. Honda CBs. Suzuki GS models. etc etc. you may need to come up with some simple brackets for the rear mounts. easy. the front sliders attach at the upper shock studs.
1981 KZ650-CSR w 550Ltd wheels 750E mufflers & 750-H3 Ltd seat.
Last edit: 05 Apr 2016 09:24 by martin_csr.
  • ChristineC
05 Apr 2016 09:16
#719377
Thanks for the info. I was going to buy another seat that wouldn't have fit.
  • davido
  • davido's Avatar
05 Apr 2016 11:30
#719391
Whats wrong with the old seat? If the base is still good you might be able to take the foam and cover off the new one and fit them on the old base.
Failing that, you could take the hinges and lock off the new seat and remount them in the right place.
Just a couple of thoughts. Im not familiar with this bike but buying another new seat should be a last resort.
Theres more than one way to skin a cat!
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • ChristineC
05 Apr 2016 11:37
#719395
The old seat is two pieces.
