New KZ owner
  • djblingbling1
  • djblingbling1's Avatar Topic Author
Re: New KZ owner
17 Oct 2015 09:56
#694895
I'll give the carb a look and mess with that needle. Frame in the rear is a 76 iron head so unfortunatly it would get an iron head engine but I'm thinking I'll sell it since the cost of the engine would get me a used evo sporty.
  • djblingbling1
Re: New KZ owner
17 Oct 2015 15:32
#694932
Fuel level seemed ok,so ok I spilled it all over my jeans, haha. I moved the needle clip to the top, re assembled it.kicked it over, nothing, put the choke up and boom, worked great. Havnt taken it for a ride yet but tomorrow ill give it a test run to let it really warm up but I think itll be perfect now!
Id love to do so many things to this bike but it seems like its coolest in stock form since it has a new seat and fresh paint, and the rest of the bike is in such great shape. 11k miles which dosnt seem to bad fora 78!
  • djblingbling1
Re: New KZ owner
17 Oct 2015 16:51
#694963
Alright tried to go for a ride and the bikes worse of than before. Choke lets it start but now it hesitates and wont idle without the choke.....II went up to the top of the needle, maybe I just need to try in between the middle and top?
  • punisher11b
  • punisher11b's Avatar
Re: New KZ owner
17 Oct 2015 17:00
#694966
That would be my guess.
- good luck
  • djblingbling1
Re: New KZ owner
17 Oct 2015 17:38
#694981
Ok just got back from a quick zip with it in between the top and middle, 2nd slot. It starts easier and feels like it has more power but is dieing at stops....if I give it a bit of gas it will idle fine but with immediate cut off of the throttle it will just drop and die.
  • BornAgainBiker
  • BornAgainBiker's Avatar
Re: New KZ owner
18 Oct 2015 00:35
#695010
What a clean little bike--nice find. :)
All the best, Jeff
1984 KZ440 D6
  • punisher11b
Re: New KZ owner
18 Oct 2015 05:27 - 18 Oct 2015 05:29
#695037
So, your saying the power is good but dies at stops. Does leaving the choke on stop this? It sounds like just an increase to idle is what you need. ( if I'm on the same page,) should just be an idle screw you can turn in to increase your rpms at idle. A trick to tell if it's just an idle screw adjustment is to see if it runs fine with the throttle cable tight enough to keep the rpms up to the correct range.
- good luck
Last edit: 18 Oct 2015 05:29 by punisher11b.
  • djblingbling1
Re: New KZ owner
18 Oct 2015 07:54
#695056
Ive been messing with it but I an set the idle to 3k but once i let off the throttle it still dies.....its weird.
Re: New KZ owner
18 Oct 2015 08:25 - 18 Oct 2015 08:25
#695058
3000 rpm is not idling. 1000 +/- 50 rpm is idling. You need to clean that carb. Ed
Last edit: 18 Oct 2015 08:25 by 650ed.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
Re: New KZ owner
18 Oct 2015 08:26
#695059
I know you said you cleaned the carb but I would suspect something in the pilot circuit.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • punisher11b
Re: New KZ owner
18 Oct 2015 08:31
#695060
ThatGPzGuy wrote: I know you said you cleaned the carb but I would suspect something in the pilot circuit.
+1
- good luck
  • missionkz
  • missionkz's Avatar
Re: New KZ owner
18 Oct 2015 08:44
#695061
+1
LOL!! There is nothing to suspect in my opinion!
The idle and pilot circuit in the carb's are dirty and or plugged.
Soaking does virtual nothing.
You must scrap crud out of tiny passage ways in the carb bodies.
Cleaning jets and brass is only half way there.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
