kz 650 front fork swap
- finelinefinishing
- Banned
23 May 2015 18:48
Hi everyone. I have a 1981 kz650 that I am cafeing and would like to update front forks and was wondering if anyone had done this and what the best plan of attack would be, I heard that zx6r front suspention will fit..??? any info would be helpful
- Randombeat
- 0 to 100 real quick...
Re: kz 650 front fork swap
23 May 2015 20:06
Search option will help you, something like "kz650 front end swap"....
Try that...
, also browse the " projects" forum...
After doing those 2 suggestions let us know if your still empty handed... Before you even finish, someone that has done a swap will probably reply to your thread....
Good luck!
Chris
Try that...
Good luck!
Chris
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
24 May 2015 06:22 - 24 May 2015 06:24
The KZ750-4 Ltd chain drive models would swap the same as the 650-CSR --- they have the same frames & triple trees.
All Balls Racing has a bearing swap lookup & you'd need to know the length of the steering head &/or triple tree stem.
Last edit: 24 May 2015 06:24 by martin_csr.
