New KZ1000 owner in MI
  • Stazi
  • Stazi's Avatar Topic Author
24 Sep 2013 23:48 - 24 Sep 2013 23:52
#607679
Hi there,
I just picked up an 1981 KZ1000. My last bike was a 2000 ZX-9R, and I miss it. I had to sell it after my first kid was born and the misses wanted me to get rid if it. 5 years later and she says I can build a café bike, so I picked a Kwaka again.
I'm trying to fix up the things that need replacing and have some essential on the way. Air box boots (they are hard as rocks and one wasn't even on the carb properly) new air filter as a mouse decided to make a nest in the air box in the PO's barn, and some other stuff. It already has a MAC 4-1 Cannister exhaust and I ordered a new baffle for it as the original is cracked.
Now my dilemma. In searching for some parts I see that for an 81 KZ1000 there are three variants. A KZ1000, KZ 1000 LTD and a KZ1000 CSR. The issue is that for fork springs, for example, the LTD and CSR use the 11-1110 springs but the "plain" KZ1000 uses the 11-1108 springs. I am seeing that the diameters on either of these id different, so that's not something to gamble on.
Is there a way to confirm my model as the bike came with now badges and all I have to identify it is the factory info sticker and the VIN. it was built in 9/81 and it's actually registered as a 1982 (WTF?). The VIN is JKAKZCK1XCA00xxxx. So what exactly do I have?
Attached is a pic of the bike as I got it..some fool along the way painted everything flat black with cheap rattle can paint, so that's gonna go...
Thanks in advance!
82 KZ1000-K2 LTD
Last edit: 24 Sep 2013 23:52 by Stazi.
  • MFolks
  • MFolks's Avatar
Re: New KZ1000 owner in MI
25 Sep 2013 00:13
#607684
25 Sep 2013 00:39
#607685
www.zedder.com
> Bike Info
> Kawasaki Model Information
> 1000 cc arranged by year
Click the various models to compare with VIN on bike at hand.
Good Fortune! :)
  • Motor Head
  • Motor Head's Avatar
25 Sep 2013 00:42
#607686
You have it right in your signature, its a LTD K1. Look at the gauges, they are electronic, only the LTD had them. Seat, Tank, etc, all LTD.
25 Sep 2013 00:43
#607687
As I recall, the standard model has front axle located at bottom of fork sliders; and the LTD and CSR models have front axles on front of fork sliders like the bike at hand.
Good Fortune! :)
25 Sep 2013 00:48
#607688
Per Zedder --
Year & Model '81 KZ1000-K1:LTD
VIN Range JKAKZCK1vBA000001 - 006900
Engine No. Range KZTOOJE000001 - 019200
Year & Model '82 KZ1000-K2:LTD
VIN Range Japan MFR JKAKZCK1vCA006901 - 009805
USA MFR JKAKZCK1vCB500001 - 503000
Engine No. Range KZTOOJE019201 -034189
Good Fortune! :)
  • Stazi
25 Sep 2013 07:00 - 25 Sep 2013 07:03
#607701
Thank you, gentlemen! That helps immensely!
Now I know the correct springs to get. Cam you direct me to who has new fork seals in stock? Partzilla is out. Also, which other parts would you recommend I pick up for a fork rebuild?
TIA, again!
Stazi
82 KZ1000-K2 LTD
Last edit: 25 Sep 2013 07:03 by Stazi.
25 Sep 2013 09:45
#607706
Stazi,
In working on these bikes and soliciting help from others it is important to know what model motorcycle you own. As Patton pointed out, the is no such model as a 1982 KZ1000-K1, but that is the model you show in your signature.
There is a 1981 KZ1000-K1 and a 1982 KZ1000-K2. Which one (if ether) do you own?
25 Sep 2013 10:20
#607715
Stazi wrote: ... who has new fork seals in stock?....
Imo, when needing parts, Z1E is the best place to start looking. :cheer:
www.Z1Enterprises.com
Good Fortune! :)
The following user(s) said Thank You: Stazi
  • Stazi
25 Sep 2013 10:52
#607718
650ed wrote: Stazi,
Thanks, OK, so I guess I have an 82 K2 as I fit inside this VIN Range Japan MFR JKAKZCK1vCA006901 - 009805
82 KZ1000-K2 LTD
