starting a build
- poohbear
starting a build
23 Jul 2013 00:56
Hey guys and my name is Clayton I'm thinking about picking up a late 70`s model kz650. I want to ,make into more of a new street bike style. Is there major thing I should be looking for? I don't know much about bikes but Im pretty mechanical inclined. I just really need some input on how I should go about the build
- 650mod
Re: starting a build
23 Jul 2013 10:24
Welcome to the forum! There's a lot of information on here, and a lot of guys who do really good work.
I'm working on my 650 build right now, check my build link:
kzrider.com/forum/11-projects/573616-650-mods-78-fighter-build
And here's another member's finished 650 build.
kzrider.com/forum/11-projects/552156-kz6...street-fighter-build
Hopefully these builds are along the lines of what you're going for.
Devin
Devin
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
- poohbear
23 Jul 2013 11:04
That is exactly what I want my build to end up like. I have a few questions tho. Did you guys have to custom build the front forks, and rear sway arm? Or were they just off of a newer bike?
- lushbaugh
- everybodys a pro......
23 Jul 2013 14:38
welcome to kzr
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- 650mod
23 Jul 2013 17:35poohbear wrote: That is exactly what I want my build to end up like. I have a few questions tho. Did you guys have to custom build the front forks, and rear sway arm? Or were they just off of a newer bike?
The only thing that's custom about the forks is the steering tube. Sometimes you can get lucky and order a bearing kit from AllBalls that is a direct fit for the new fork tube to the KZ steering stem. Other times you have to lathe/weld/modify the KZ stem to take the new stem. It's a bit of massaging, but really not that bad. My front end is off a 2001 Buell Lightning 1200. Just had to customize the stem from the Buell forks to take my KZ bearing tubes.
The rear end is also a plug and play type build. I'm using a swingarm off a '98 ninja 600 (converting to monoshock). Depending on the arm, you'll have to either widen your frame a little at the pivot tube mount, or mill down the swingarm. then you have to make tophat spacers to fit the KZ pivot bolt to the diameter on the arm. Just takes some good measurements and a skilled machinist.
Keep us updated on the build.
78 kz 650 custom
- poohbear
26 Jul 2013 11:35
is there alot of benifits from changing the swing arm? i know that the new forks will add a lot of handling and thats my main concern. i mean if there isnt much pay off from doing the swing are should i even bother.
- 650mod
26 Jul 2013 12:25
It's totally your call on whether you want to do the ass end at the same time. I'd do it because you gain better suspension in the back to complement the front. Switching over to the monoshock with the ninja rear end stretches the wheel base by 3.5 inches, and gives you a much smoother, more adjustable rear suspension. Again, your call with how much work you're wanting to get into. The other thing you could do is upgrade your rear shocks to a good high-end set if you're wanting to keep the stock swinger on there.
78 kz 650 custom
