New Member! 1981 KZ750 LTD
  • krzyryder
  • krzyryder's Avatar Topic Author
15 Jul 2013 13:40
#596617
Hello All,
Just picked up an 1981 KZ750 LTD in great condition for a great price......FREE! :woohoo: PO had it garaged but hasn't been started in 15 years and was about to donate it. Pretty excited about getting this ol girl up and running. Haven't decided which direction I want to go with her at this point. The PO lost the keys so Rob here on the forums is cutting me a couple....then I'll start digging into her. I'm sure I'll be hitting you guys up with lots of questions.
Thanks,
Ray
Attachment IMG_1880.JPG not found
Attachment IMG_1877.JPG not found
Attachment IMG_1875.JPG not found
Attachment IMG_1873.JPG not found
Attachment IMG_1871.JPG not found
  • upncummr
  • upncummr's Avatar
Re: New Member! 1981 KZ750 LTD
15 Jul 2013 17:46
#596641
Welcome to the forum.
That's a nice looking bike and a GREAT price! It's really hard to beat free.
The following user(s) said Thank You: Cynjut, krzyryder
  • Cynjut
  • Cynjut's Avatar
15 Jul 2013 18:26
#596644
... except for free kittens and fish.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
  • krzyryder
27 Jul 2013 02:24
#598527
Hello all, can someone tell me what this is (red arrow)? And if the B/W wire coming from it connects to the ground? The PO had an alarm system installed which I just removed and didn't know if I'm missing something.
Attachment wiring.jpg not found
  • krzyryder
27 Jul 2013 02:53
#598528
I'm not seeing a module with a B/W and L/W wire coming out of it in Clymer wiring diagram either?
  • martin_csr
  • martin_csr's Avatar
27 Jul 2013 11:26 - 27 Jul 2013 17:15
#598543
That is the accessory fuse box, which has 2 fuses. One fuse is for the black/white accessory lead. The other is for the blue/white accessory lead which probably terminates at the headlight bucket.
FYI. Stock, the acc fuse box sits directly behind the rearward side cover mount, fitted onto a bracket.
In your photo you can see the bracket mounting slot in the rubber.
Here's a site w a manual & wiring diagrams. Scroll down & click "The Bible" link. mbsween.bike-night KZ750L3 page
Some of the wiring diagrams are mislabeled in the links. The 1981 is an H2 & the 1982 is an H3.
search tags mbsween KZ750L3
Here's the KZ650-CSR electrical stuff which is very similar to your bike.
Last edit: 27 Jul 2013 17:15 by martin_csr.
  • krzyryder
27 Jul 2013 15:36
#598573
Awesome thanks. I need to clean up some spliced wires and charge he new battery and ill try to see if she turns over tonight. Wish me luck!
  • krzyryder
02 Aug 2013 11:10
#599523
A little progress last night. Cleaned up all of the spliced wiring and put the new battery in. Pulled the clutch and hit the start button and only get clicking. Tested battery voltage and its strong. Used screw driver on starter solenoid and the tries to turn over. OK.....ordered new solenoid. I did hear some bad noises when she was trying to start though.....not sure if the starter motor is going bad or not. I'll need to clean the tank, carbs and replace fuel lines before trying to start her again. At least I know the wiring is fairly solid for now.
