1979 kz1000 st
  • tagenz
  • tagenz's Avatar Topic Author
1979 kz1000 st
04 Jun 2013 14:25
#590826
recently bought a 1979 kz1000 st for $400. rebuilt the carbs, open filters, new plugs, factory sealed battery, and a number of other little improvements. got it running pretty good so took it on a couple rides around town. oil started leaking from the right head gasket. i have new gaskets here but need a little step-by-step how-to on removing the cams and head. im not new to wrenching...but i am new to timing and cams. any help would be appreciated. thank you.
Re: 1979 kz1000 st
04 Jun 2013 14:31
#590828
Before you go any further clean the area around the leak very well then check to make sure the leak isn't from the tachometer drive connection. This is a very common problem that can be very easily fixed, and it is often mistakenly diagnosed as a head gasket leak. Ed
  • tagenz
Re: 1979 kz1000 st
04 Jun 2013 16:35
#590841
oh nice. that would make this so much easier...thanks.
