New Rider-Tampa, FL
- Joe89
New Rider-Tampa, FL
22 May 2013 05:14
I'm a new rider all together and loving every minute of it!!
It might be an un-intelligent question but here goes anyways....
Just got my KZ750 Spectre a couple months ago after rebuilding carbs, syncing, new plugs, rebuilt the time advancer that was froze up and changed the oil. I'm having an issue with the oil plug leaking and vibrating loose. Like I said stupid problem. I don't recall seeing a rubber washer or o-ring or anything of the sort that would stop it from vibrating loose.. am I missing something or did I just not have it torqued enough? The person before me had his hands in it and had no idea what he was doing. Me being new it wasn't very helpful to not know what if anything was missing.
Any advice would be greatly appreciated as the world of motorcycle mechanics is very new to me. Thanks, Joe.
Attachment KZ750Spectre.jpg not found
- Joe89
Re: New Rider-Tampa, FL
22 May 2013 07:23
I promise its not because I am incapable of doing the work, there is a difference between pulling something apart cleaning it and putting it back together and knowing whether or not something was supposed to be there or rigged before I had the chance to see how it came apart.
- KZJOE900
- Admin
22 May 2013 09:04
The oil drain plug should have an o-ring that resides in a grove that mates against the oil pan surface. Go to Advanced Autoparts or Autozone and ask them to see Fram oil filter for that model/year bike. They are about $6.00. The Fram oil filter come with the small o-ring for the drain plug and the larger oil ring (about 4 in. dia.) for the oil filter plate. May as well purchase it if it looks like its there and use that small o-ring immediately even if you don't plan on changing out the filter. You will have to drain the oil to put that o-ring on anyways. Good luck.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
22 May 2013 09:58
Part #92065-097 looks more like an ordinary washer, but Kawasaki calls it a "drain plug gasket."
Click here > www.z1enterprises.com/ItemDetails.aspx?i...ki&item=ZSM800-12000
- Joe89
25 May 2013 00:54
Thank you for the info.
Lucky for me I happen to have an industrial o-ring kit sitting around and was able to find what I needed.
Thanks again for the help!
Joe
Joe
- ArmyDave
25 May 2013 12:29
Great Looking Spectre :woohoo:
I told you to stop bein' a tightwad & just give him the $
-Ozzie
"You dont only live once...you only die once...you live everyday!"
1980 KZ750G
-Ozzie
1980 KZ750G
- Spectre1982
25 May 2013 18:00
Torque drain plug to 27 ft-lb. Filter mounting bold is 14.5-ft-lb.
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
1978 Kawasaki KZ200
- Spectre1982
25 May 2013 18:01 - 25 May 2013 18:36
Torque drain plug to 27 ft-lb. Filter mounting bold is 14.5 ft-lb.
EDIT: Sorry for double post. Internet is acting up.
1978 Kawasaki KZ200
1978 Kawasaki KZ200
Last edit: 25 May 2013 18:36 by Spectre1982.
