A little advice
- Cajun
Re: A little advice
08 May 2013 22:18
So. I told my lady that I was getting out of bed for some water and went to wiggle the hell out of it. Worked like a charm. Unfortunately no time to play around with it anymore tonight, but ill be thinking about it till tomorrow. Thanks everyone for the tips today.
1978 KZ650 D1
- Haybus
- Big Al
Re: A little advice
08 May 2013 22:44 - 08 May 2013 22:44Cajun wrote: So. I told my lady that I was getting out of bed for some water and went to wiggle the hell out of it.
I've done that many times. :laugh:
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
2005 FJR
2009 Hayabusa
Last edit: 08 May 2013 22:44 by Haybus.
- elfmagic17
Re: A little advice
08 May 2013 23:15Cajun wrote: So. I told my lady that I was getting out of bed for some water and went to wiggle the hell out of it. Worked like a charm. Unfortunately no time to play around with it anymore tonight, but ill be thinking about it till tomorrow. Thanks everyone for the tips today.
CAREFULL that will get you in trouble....(working on the bike when your supposed to be doing something else) Ask me how I know LOL.
Kenny Hicks
74 Honda CB550
74 Honda CB550
- Powerstroke_fan
Re: A little advice
09 May 2013 08:11
hey good luck with the bike, I see you live in cierco indiana? Is that up by Ft wayne? I live between indianapolis and ft wayne. Its nice to see fellow kz riders from indiana.
1977 KZ 1000 work in progress
- Cajun
Re: A little advice
09 May 2013 08:30
Cicero is about 1/4 of the way to Ft. Wayne from Indianapolis. I just moved up here from Houston, TX. Originally from Lafayette, Louisiana. Thanks for sending good juju my way. I'm going to be working on troubleshooting the starter tonight and cleaning off and changing the electrical tape or replacing the wires on a few spots that were apparently patched up a few years ago. Then I will put on the new seat and either order a new starter if it is the issue or whatever part I need. Hopefully I can get a little riding time in tomorrow. Also found a small knob right above the carbs towards the center of the bikethis morning before work that when adjusting SIGNIFICANTLY improved the idle in neutral. I dont remember what it does exactly, i am assuming that it has to do with gasoline flow. Don't have my manual at work because I can't trust myself to not spend my day looking at it.
1978 KZ650 D1
Re: A little advice
09 May 2013 09:01 - 09 May 2013 09:01
That knob adjusts the throttle stop. It simply moves the throttle stop which in turn adjusts the idle, it doesn't directly touch fuel flow. Ed
Last edit: 09 May 2013 09:01 by 650ed.
- Cajun
Re: A little advice
09 May 2013 09:17
That makes perfect sense. If the point at which my throttle was stopping when release from my grip was past the minimum point at which the throttle needed to be in order for the engine to idle then adjusting this screw would remove the gap between those two points. Great!
1978 KZ650 D1
