Hi from Sacramento
  • sig
  • sig's Avatar Topic Author
Hi from Sacramento
26 Apr 2013 12:26
#584106
I just bought my first bike, a 1982 kHz 650, had my m1 for about 5 years. Once it's fixed up I plan to ride it daily.
1982 KZ650H CSR
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
Re: Hi from Sacramento
26 Apr 2013 13:50
#584120
Welcome to the forum sig! I am also in NORCAL (Elk Grove) Pics are always welcome.
  • sig
26 Apr 2013 15:43
#584132
Here she is!
1982 KZ650H CSR
  • sig
26 Apr 2013 17:24
#584146
Slayer61, I've got a bit of work to do on my bike. Do you know any shops or private techs in our area? This kz seems to have mostly original parts and it would be great to keep it stock.
1982 KZ650H CSR
  • slayer61
  • slayer61's Avatar
26 Apr 2013 18:47
#584157
Sig,
There is a little shop in Stockton called Stockton Moto, of all things, and Rich, the mechanic has a large following of customers from his previous employer, the local Suzuki-Kawasaki dealer. You might give them a shot. That's all I got. Sorry it's not closer to you, but it's the area I am from. Paul
  • sig
26 Apr 2013 22:16
#584180
Thanks for the heads-up slayer. It's good to know that there's a shop somewhere that I can take this thing if I need to.
1982 KZ650H CSR
  • sig
25 May 2013 02:42 - 25 May 2013 02:42
#589094
Just an update.
Got the carbs in, attached the boots to the air box, installed the head lights, swapped the blinkers from front to back, slapped on the side covers, then gave her her first hose down!
Still need some things, new speedo, throttle, tach cables. Front MC, handlebars, filters, pads, tires, lastly a paint job.
Took her on a longer circuit around the neighborhood too! Got up to 4th gear but with no license plate I gotta be careful!! Runs really nice warmed up in about 5 minutes to ride with no choke.
Attachment image_2013-05-25.jpg not found
1982 KZ650H CSR
Last edit: 25 May 2013 02:42 by sig.
  • lightitup
  • lightitup's Avatar
25 May 2013 04:39
#589105
looks good i was thinking of doing the same think with the blinkers did it take much modding
81 kz 550 ltd
  • sig
25 May 2013 12:07 - 25 May 2013 20:14
#589128
I had to file down the splines near the end of the stems. Get a good Swiss file and it takes around 30 minutes. Some aftermarket parts look smooth on the end, might save time.
1982 KZ650H CSR
Last edit: 25 May 2013 20:14 by sig.
  • ArmyDave
  • ArmyDave's Avatar
25 May 2013 12:28
#589134
Hello and Welcome!
I told you to stop bein' a tightwad & just give him the $
-Ozzie
"You dont only live once...you only die once...you live everyday!"
1980 KZ750G
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
25 May 2013 21:19
#589183
Welcome Sig.
Nice start on the bike.
Do get yourself a front brake asap.
Getting into 4th means you must be building up some speed, and will need to stop too.
Have fun and ride safely.
B)
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • boatdrinks
  • boatdrinks's Avatar
25 May 2013 21:23
#589185
Welcome aboard!
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
