New to Forum pt.2 Oh no, what have I gotten into?
- geohaydook1
27 Mar 2013 15:05
First, I'd like to thank you all for making me feel welcome.This looks like a great site.
I was a mechanic at an independent M.C. shop in northern California back in the 1980s and I learned that the hardest bike to work on was one someone else had worked on...and given up.
And that is just what I have here. I've had a few days to check out my "new" 750e and every day reveals another nasty surprise.
1.Went to change oil and filter...no filter, spring, or o-ring.
2. Pulled carbs for inspection and found a broken carb body where the p.o. tried to remove the air screw plug..and also broke the screw itself.
3. Checked valve clearances and found 5 valves with less than .038 clearance (my smallest gauge).
4. Missing clutch push rod.
5. Spun engine with electric starter and found NO OIL reaching the cams.
The fun continues.I have restored/re-animated many bikes over the years, and this looks to be my greatest challenge.Anybody need a boat anchor? :pinch:
1980 KZ750e
1981 KZ650 csr (fate undecided)
- wireman
Re: New to Forum pt.2 Oh no, what have I gotten into?
27 Mar 2013 15:15
Welcome to z-jungle.
27 Mar 2013 17:24
This probably doesn't apply here, but your bike is a good example of why to never believe an ad that says "All it needs is...."
You may find this humorous - someone on another forum said the same thing about a missing oil filter n stuff... he was trying to find it by looking under the crankcase breather cover. hee.
