Need Guidance Bike Will Not Start
  • enjelly
  • enjelly's Avatar Topic Author
30 Dec 2012 10:21 - 30 Dec 2012 13:02
#565146
1977 KZ1000 Dyna Ignition
Biked fired up when purchased. Trouble started when I replaced the battery.
The starter cranks the engine. There is gas to the carbs and good compression. Pulled a plug and it will not spark when touching the block but will spark when isolated from the block. The kill switch is missing the control knob. Should the contact be bridged or left open to be in the run position.
Any ideas where to start.
Thanks for the help
Last edit: 30 Dec 2012 13:02 by enjelly.
  • trianglelaguna
  • trianglelaguna's Avatar
Re: Need Guidance Bike Will Not Start
30 Dec 2012 12:59 - 30 Dec 2012 13:00
#565148
those need to be twisted together i believe....been a while but that is what i think...wont hurt it to try....the red battery cable also has a wire that comes off it (white/or white red stripe)and maybe even an inline fuse to the harness/fuse box where there is a main fuse...did you maybe pop a fuse when changing the battery
oh and just for nothing it is a dyna ignition
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 30 Dec 2012 13:00 by trianglelaguna.
30 Dec 2012 15:53
#565163
enjelly wrote: 1977 KZ1000 Dyna Ignition
Thanks for the help
-- more elaboration could be helpful.
Good Fortune! :)
  • enjelly
30 Dec 2012 20:50 - 30 Dec 2012 22:32
#565196
Initial test pulled the plug, set it on the block, cranked the engine, no spark. To get a better look, set the plug on a rubber screw driver handle, cranked the engine, big blue spark. Found a loose wire Blk w/yellow (pic attached) but can not locate the other end. There is an open wire in the harness from the Dyna 2000 box to the coils (same pic). The blinkers, headlight and gauge lights work. Let me know if you need any additional info. Thanks,
Last edit: 30 Dec 2012 22:32 by enjelly.
  • MFolks
  • MFolks's Avatar
30 Dec 2012 21:30
#565197
Black with Yellow stripe wires are usually ground circuits, so look for the mating end(most are Bullet connectors)or ring terminals.
  • enjelly
01 Jan 2013 19:07
#565473
Problem resolved - replaced all 4 spark plugs
The plugs were internally shorted...When off ground they sparked but when grounded the path was already completed, no spark.
