KZ1000st Project
  • DesertKZ
  • DesertKZ's Avatar Topic Author
KZ1000st Project
23 Aug 2012 18:10
#544357
Hello all. I'll be trolling your boards for awhile as I fix up this 79 KZ1000st. I'm out in AZ!
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
  • kawasaki mike
  • kawasaki mike's Avatar
  • kawasaki mike
Re: KZ1000st Project
31 Aug 2012 02:01
#545821
Troll away fellow. We have a decent following and all are addicted to the mighty kz. Shoot us some pics as we all love kz porn. (With or without the girls)
Am addicted to Z1's and kz 900's have an el camino, fly rc helicoptors and am strung out on horsepower.
  • Je77ekz1000a
  • Je77ekz1000a's Avatar
31 Aug 2012 09:35
#545856
Welcome desertkz
Can't wait to see the turn around on this bike, always exciting to see everyones personal touches B)
Jesse Shasteen
77 KZ1000 A
Huntsville AL
  • DesertKZ
31 Aug 2012 15:00
#545896
Je77ekz1000a wrote: Welcome desertkz
Thanks a bunch. My GF is pissed because I'm in the garage every night. The bike had sat for a few years before I got it. I rebuilt the carbs, checked valve clearance, fresh gas and it fired right up. I stripped it down (took the fairing/luggage off), new tires, set of clip-ons and will hopefully have it on the road in the next couple of weeks.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
  • MFolks
  • MFolks's Avatar
31 Aug 2012 15:07
#545898
If you have not cleaned the many and various electrical switches and connectors, read this on how to do it:
Cleaning Motorcycle Electrics
1. Get some of the De-Oxit electrical contact cleaner and figure on spending a good day going from the front of the bike to the back. It’s a plastic safe cleaner/preservative. www.deoxit.com is their website. It can be purchased at most Radio Shack Stores or any electronic supply places. Or use any plastic safe electrical contact cleaner(NOT WD-40 !).
2. On the older Kawasaki's, a majority of electrical connectors are inside the headlight housing requiring removal of the headlight, then the fun begins.
3. Do one set of electrical connectors at a time to avoid mixing up what connects to where. Usually disconnecting, spraying with De-Oxit and reconnecting is about all you'll need.
4. However, when encountering the green crud of corrosion, a brass wire brush may be needed on the pins you can reach.
Some 400-600 grit wet and dry sandpaper strips rolled into a tube should reach the male and female pins in the more difficult to clean connectors.
5. Smoker’s pipe cleaners, cotton swabs and wooden toothpicks work as cleaning aids.
6. Really small electrical connectors may require the use of a welders tip cleaning tool assortment.
7. Most pins in the connectors are coated with a thin plating of tin, and others may be nothing more than copper or brass.
8. If moisture is added, the resulting corrosion lowers the voltage/current being carried causing dim lights, slow engine cranking, slow turn signal responce and lower input voltage to the ignition coils resulting in weak spark.
9. The left and right handlebar switch pods will need attention too as they have circuit functions like turn, horn, run/stop, and start. The older Kawasaki’s have reports of the soldered connections crumbling, if your bike has this problem, just ask, as I’ve got a repair procedure for this.
10. Usually a spritz or two with actuation of the switch is about all needed for these switches unless corrosion is detected and then careful disassembly is required.
11. The ignition switch may or may be not sealed to allow spraying the internal contacts. I urge caution if attempting to open this up as springs, and ball bearings may fly out never to be seen again!
12. If your bike has the older style glass tubed fuses, I suggest replacing them as vibration can cause internal failure. AGX is the type used, and most auto parts stores can get them for you, along with boating supply stores.
13. Clean the fuse holder clips, looking for signs of overheating(discolored insulation, signs of melting).
I use metal polish on a cotton swab, followed by spraying another clean swab with the De-Oxit and then rubbing the inside of the fuse clip.
14. All battery cables must be clean and tight for maximum current transfer. Check the cables going from the Negative(-) battery terminal/post to the engine mounting bolt
15. Also the one going from the Positive(+) terminal to the starter solenoid and from there to the starter motor.
16. If any battery cable feels ”Crunchy” when flexed, replace it as possible corrosion is inside the insulation. Inspect all heavy duty battery cables and the smaller wire terminations(Bullet Connectors), for failed crimps, and those used in the electrical connectors, as they can fail over time.
17. Each "Bullet Connector" will have to be sprayed to ensure good connectivity, especially the ones going to the energizing coil of the starter solenoid.
18. The alternator output “Bullet Connectors” are usually behind the engine sprocket cover and will need inspecting and cleaning too.
20. The turn signal light sockets will benefit from a spritz from the contact cleaner along with the tail light/brake light socket.
21. Some brake light switches can be sprayed on the actuating rod, with the spray running down inside to the electrical contacts, others may be sealed requiring replacement if the switch is intermittent in operation.
22. Some people put the Di-Electric Grease on cleaned terminations/connectors, I don’t, as I’ve read/heard it can cause problems when it gets hot, actually insulating the connections, so the choice is yours to use or not.
“I spent a weekend going through every electrical connection and switch on the bike with a little scotchbrite pad and DeOxit - what a difference! Everything was brighter, gauge backlights, indicator lights, turn signals, I was getting a nicer spark, it fired up quicker, etc. Well worth my time. WELL worth it! “
From a forum member at www.kzrider.com
Why WD-40 Should Not Be Used On Motorcycle Electrical Items.
For many years, I was proponent of the use of WD-40 on fuse clips, fuses, switches and connectors. After hearing of other peoples experience with intermittent and sporadic activity, I shrugged it off as maybe they did something wrong in the application of the product.
It wasn’t until the time I rode my 1982 GPz1100 B2 model to downtown San Diego that I encountered the problems others had gone through.
After concluding my business downtown, I walked to where my bike was parked, turned the key to unlock the forks, and prepared to start the engine. The key was in the "On" position, yet I had no lights in the dash panel, the fuel pump was not running(I have FI), and the horn and tail light were not working.
Puzzled as to why nothing electrical was happening, I remember my earlier conversations about how WD-40 will over time become a non-conductor(more like an insulator). I had some pieces of 400 and 600 grit sandpaper in my tool kit and with them was able to scratch away the coating from the WD-40 on the fuses and clips.
After removing the insulating film, the bike started and ran like it should. Since that time, I’ve told people about the problem with WD-40. If you must use a contact cleaner, I recommend getting some "De-oxit" from Radio Shack Stores or any good electronic supply store.
If you encounter failed or failing solder joints(the older bikes may be suffering from this), I've got a repair procedure, just ask....
  • DesertKZ
31 Aug 2012 15:25
#545903
Thanks MFolks, great info in there.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
  • VirginiaKZ
  • VirginiaKZ's Avatar
14 Sep 2012 06:23
#548595
Hey Desert, I got an '80 ST over the summer I'm messing with. Yours is pretty unmolested from stock. Wacha gonna do with the luggage and mounting stuff?
1980 KZ1000 ST
  • DesertKZ
19 Sep 2012 13:10 - 13 Mar 2013 18:23
#549670
Attachment not found
You know I haven't really decided yet. It's on a pallet covered up in my backyard, in really good shape. It's certainly not going back onto the bike but everything's there (minus stereo/speakers).
Wiring has been a nightmare so far. The PO installed a trailer harness and the front is hacked up from the stereo/speakers. As of now I can't get my signals to flash (even though I replaced the flasher) and my brake light won't illuminate.
*****EDIT*****
All lights are working, woo hoo!!!
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
Last edit: 13 Mar 2013 18:23 by DesertKZ.
  • DesertKZ
13 Mar 2013 18:25
#576850
Bike's done and passed emissions last week. Weather's beautiful in Phoenix and it's time for some riding....
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
14 Mar 2013 11:53
#576918
looks good!
enjoy the riding season.
