Hello all! 1982 KZ 750CSR
  • Kenter
  • Kenter's Avatar Topic Author
26 Jul 2012 00:44
#538711
I made the deal of a lifetime. I traded my old 2.9L out of my broncoII for a 1982 Kawasaki 750CSR! It runs great and drives even better. It needs a little maintenance but other than that its great! I have found the carbs needed to be cleaned. So I've done that but I've noticed the boots connecting the carbs to the air box are kinda a PITA to get back on the carbs... I cleaned them like I said but my dad wanted to take it for a spin and drove it down a dirt road. The boot on the one carb wasn't on very well so needless to say the carbs need to be cleaned again. Is there a secret to those boots or is there a way to eliminate the air box and get two separate air cleaners for it?
  • faffi
  • faffi's Avatar
Re: Hello all! 1982 KZ 750CSR
26 Jul 2012 03:12
#538727
I would not go with individual filters unless you want to fiddle with jetting - and still probably not succeed. You can gently heat the rubbers with a hair dryer to make them more pliable during installation, that may do the trick.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
26 Jul 2012 08:37
#538740
If you can't soften the boots just replace them. When new they are soft and easy to install; over time they get hard. Read through this thread:
kzrider.com/forum/3-carburetor/534332-ho...ots-on-my-csr#538151
  • martin_csr
  • martin_csr's Avatar
26 Jul 2012 09:14 - 22 Jan 2013 20:54
#538743
The airbox ducts may not be available any more - they're listed as OBSOLETE at PowerSportsPlus.com.
Last edit: 22 Jan 2013 20:54 by martin_csr.
26 Jul 2012 09:53
#538750
martin_csr wrote: The airbox ducts may not be available any more - they're listed as OBSOLETE at PowerSportsPlus.com. Some guys fabricate the ducts - someone over at the KZ400.com site used a fork gaiter to make two, but I don't know what bike.
Oooops; you are right - part #16065-1046 is discontinued. I searched the normal parts houses and could not find any. There is 1 on eBay; I would grab it while I could; then you only need to struggle with 1 boot until another shows up.
  • Calico
  • Calico's Avatar
26 Jul 2012 10:03
#538752
I've only had to do this a few times but instead of heating I just used a VERY light coat of petroleum jelly and some patience.
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
  • martin_csr
26 Jul 2012 12:12 - 22 Jan 2013 20:54
#538764
An alternate way to heat them is to use hot hot water.
  • Kenter
27 Jul 2012 02:13
#538929
Thanks everyone for the suggestions I'll have to try em out and see what I can come up with. I wanna ask if you guys know where I can get (don't laugh) a sissy bar and some highway bars for my new toy?
  • martin_csr
27 Jul 2012 09:23 - 22 Jan 2013 20:55
#538961
never mind - wrong bike doh
Last edit: 22 Jan 2013 20:55 by martin_csr.
  • Kenter
30 Jul 2012 19:48 - 31 Jul 2012 01:36
#539611
Well I got other troubles it seems the starter is gone it makes a long loud grinding clicking noise when I push the starter button. Even after I let go of the starter switch it still cranks for a few seconds. Although if the bike gets warmed up it starts without a problem. I did a little diagnosis on it before I had to go to the Slavezone. I thought maybe the battery was weak but after I hooked up the battery charger it did the same thing just with more power. I hope its not a starter those things are ridiculous! Four and some change from rocky mountain atv/mc.
Last edit: 31 Jul 2012 01:36 by Kenter.
  • martin_csr
31 Jul 2012 02:15 - 22 Jan 2013 20:54
#539674
