Hello from the UK
- t0ne
Hello from the UK
15 Jul 2012 18:32
Hello all, I've recently picked up a lovely 1977 KZ1000 LTD that was imported into the UK in the early 90's. I think it's had a few tweaks over the years and needs a bit of love as it's not quite running right yet. I rode it the 100 miles or so home from where I bought it and it was lacking power and wouldn't idle below about 2000rpm. I've been wanting a big Z for years and am looking forward to bringing it back into tip-top condition
- Motor Head
Re: Hello from the UK
15 Jul 2012 19:40
When you get a chance post some pictures of your new Bike!
Everyone likes to see what you got, there.
Lots of good carb info in "File Base"- Non specific models, at the top right corner of the KZR page.
The following user(s) said Thank You: t0ne
15 Jul 2012 21:36 - 15 Jul 2012 21:38t0ne wrote: Hello all, I've recently picked up a lovely 1977 KZ1000 LTD that was imported into the UK in the early 90's. I think it's had a few tweaks over the years and needs a bit of love as it's not quite running right yet. I rode it the 100 miles or so home from where I bought it and it was lacking power and wouldn't idle below about 2000rpm. I've been wanting a big Z for years and am looking forward to bringing it back into tip-top condition
Perhaps the engine is combusting on just two of its four cylinders.
May start the COLD engine, and after a few seconds of running, spray water mist onto the four exhaust header pipes (using a common household sprayer).
When a cylinder is combusting, the water will instantly vaporize and sizzle off the pipe.
When a cylinder is NOT combusting, the water will just run down the pipe.
The results of the water spray test may aid further diagnosis.
Last edit: 15 Jul 2012 21:38 by Patton.
- t0ne
16 Jul 2012 09:13 - 16 Jul 2012 09:51
Last edit: 16 Jul 2012 09:51 by t0ne. Reason: Linked to images
