Time to build something I don't run into rocks
  • Kzzzz750
  • Kzzzz750's Avatar Topic Author
11 Jul 2012 16:34 - 11 Jul 2012 16:44
#535281
Hey y'all I am building a 78 Kz750 that my brother gave to me for free :P . I have a background in custom fabrication for Jeep rock crawlers. Ive built some pretty extreme stuff in my past and have basically full metal fab shop built in my garage. I also have a buddy that's been building-racing bikes for over ten years so between the two of us we should be able to make a sweet budget modern looking cafe racer.
Here is how she started
Last edit: 11 Jul 2012 16:44 by Kzzzz750.
  • Kzzzz750
Re: Time to build something I don't run into rocks
11 Jul 2012 16:43
#535284
We started the easy process of stripping every thing down
  • Kzzzz750
11 Jul 2012 16:48
#535285
And then cutting off all the old brackets and tabs.
  • Kzzzz750
11 Jul 2012 17:03
#535286
We are going to probably use a harley vrod headlight and lower it so the top is flush with the tank. Already stripped the instrument cluster and probably gonna just run a small tach w/ mpg. We are toying around with the idea of monoshock. Went to a 40 tooth sprocket in the rear. And got the whole rear wheel cleaned up. and put on 2 little intake filters
  • faffi
  • faffi's Avatar
11 Jul 2012 17:31
#535292
Well, you've certainly set the bar pretty high for yourself ;) Will be fun to follow the development.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
11 Jul 2012 18:07
#535299
Might be time for a new rear tire? :laugh: :woohoo:
  • Kzzzz750
11 Jul 2012 19:43 - 11 Jul 2012 19:44
#535324
faffi wrote: Well, you've certainly set the bar pretty high for yourself ;) Will be fun to follow the development.
I have been doing pretty serious metal fabrication for the last five years
I hand build almost every piece of my suspension components.
And have acquired bout $10-12k in fabrication tools. So I'm thinking with my buddies knowledge and my fab skills it should be do able super cheap.
And yes new rubber is definately on the list.
Last edit: 11 Jul 2012 19:44 by Kzzzz750.
