My first KZ!
- adr3naline
My first KZ!
09 May 2012 03:26
Hey there! I just got a 1979 KZ650sr. Last time it started was last fall, so not too bad. I'll get it to fire up tomorrow once I can work on it a bit. I'm expecting it to be the battery, but we'll see. Anyway, I'm excited to have this bike!
So, here's my question: Is there anything I need to check on with this bike right away? Or recommendations based on what you all already know? I'd love your expertise and experience to let me know if there are any known problems I should look out for. Thanks!
adr3naline
1979 KZ650sr
1979 CB650
1979 KZ650sr
1979 CB650
- rstnick
Re: My first KZ!
09 May 2012 17:55 - 09 May 2012 17:57
Welcome.
Congrats on finding a KZ.
Go over the whole bike, checking everything in the maintenance chart, including the tires.
If they are older than 5 years old, you should consider replacing them.
There should be a 4 digit date stamp in the tire sidewall, something like 2204, which is the 22nd week of 2004.
Have fun and ride safely.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 09 May 2012 17:57 by rstnick.
- graywolfracer
Re: My first KZ!
09 May 2012 17:59
Make sure your carbs are are cleaned and you have fresh gas and oil, thats there is no rust in the tank, brakes are good and so are the tires...have a fun ride
- jeffasaki
Re: My first KZ!
09 May 2012 18:06
I dont think Ive ever seen a fuel tank like that before
Very unusual
Check the carbs open up the drains on the bottom of the bowls
If it looks gummy give them a shot of carb or brake cleaner
Check the points clean em if they have any corrosion
check the plugs and clean em if required
check the oil and give it a sniff if it smells of gas replace
you can squirt some gas right into the chambers to get it going if the carbs are bunged up
some times doing this will get clean fuel running through the carbs and help clean em out
that tank is different then what Ive seen before
Very unusual
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- adr3naline
Re: My first KZ!
10 May 2012 02:27
Thanks guys!
I got her fired up, but she's not running real smooth. I've removed the carbs and tomorrow (once there's more light) I'll be tearing them down to clean and inspect. I suspect they just need a good cleaning. I hope I'm not opening a can of worms because I haven't researched this yet (sorry), but if I chose to put pods back on instead of the air box... can I expect to tune the carbs after re-jetting to get the bike to run good... or is it highly recommended to only use the air box?
Also, I removed the oil fill cap, and I expected to see a dipstick, but there wasn't. So is the oil level supposed to be determined by looking inside the filler hole? Or what?
Thanks again, I look forward to making this bike work good again, and getting to know you all.
adr3naline
1979 KZ650sr
1979 CB650
1979 KZ650sr
1979 CB650
- jeffasaki
Re: My first KZ!
10 May 2012 09:06
If it aint broke dont fix it
If its running good ride and enjoy it
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- jeffasaki
Re: My first KZ!
10 May 2012 09:07
there is a window in the clutch cover to check oil level
down behind the shifter
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Re: My first KZ!
10 May 2012 09:22
Keep the airbox!
- ramtough_63
Re: My first KZ!
10 May 2012 09:31jeffasaki wrote: If it aint broke dont fix it
+1
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- rstnick
Re: My first KZ!
11 May 2012 23:09Keep the airbox!
+1.
And get yourself a service manual.
Factory Service Manual (FSM) is best, and make sure it's for your year and model.
There are some service manual downloads kicking around for some models.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- adr3naline
Re: My first KZ!
12 May 2012 01:33
I just cleaned the carbs over the last few days... and today after putting them back in, the bike idled real nice! I spent a good long while doing everything I could to get the boots from the air box onto the carbs... the two middle boots were easy, but the end boots were impossible! I couldn't get them! Do you have tips on getting these boots on?
Here's a link to a video of it running today: My KZ650
adr3naline
1979 KZ650sr
1979 CB650
1979 KZ650sr
1979 CB650
- jeffasaki
Re: My first KZ!
12 May 2012 01:38
told ya
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
