FIX MY FUEL INJECTED BIKE
  • zelsdad
  • zelsdad's Avatar Topic Author
10 Oct 2011 10:50
#482326
this is a great site ,its the only place where people seem to know older bikes are fixable ,
i have followed many of the tips from members on this site, did some stuff i would have never tried especially at my old age to get this first of the fuel injection back on the road ,so before i give up and put this great looking 1980 classic up for sale , im asking ,is there any wrenches in the detroit area who wants a shot at getting this bike back in shape ,and back on the road. i dont know if im allowed to list my phone #
  • Motor Head
  • Motor Head's Avatar
Re: FIX MY FUEL INJECTED BIKE
10 Oct 2011 11:20
#482333
Sorry not very close to where you are.
Just wondering how far you got towards getting it going?
  • DoubleDub
  • DoubleDub's Avatar
10 Oct 2011 13:18
#482338
I'm sure somebody would buy it. If you're not interesting in fixing it yourself, there still exist shops that can work on it, but they get to be harder to find.
  • zelsdad
10 Oct 2011 22:29
#482444
i will do a list of what i have done so far
that may help me keep moving
thanks
  • Motor Head
10 Oct 2011 22:31
#482445
zelsdad wrote: i will do a list of what i have done so far
thanks
That would help anyone who was going to work on it as well. Also If you can describe symptoms it has, if it runs at all.
  • zelsdad
12 Oct 2011 23:13
#482844
After receiving the kaw I did the following :
Replace plugs , while Pulling the plug wires I noticed the caps had been replaced by ngk hard plastic ones . a little research showed that the original coil , wire and cap were one piece
I replaced the coils
I replaced the fuel line filter
And cleaned the fuel shutoff valve
Drained and replaced fuel
Replaced battery
Checked every wire from control box to the end of main harness for continutity
Checked air box for freedom of movement
Took the bike to a Kawasaki power sports shop, 400 dollars later they were stumped
Read , in this site about the unknown inline filter ,in fuel pump inlet.
The bike then ran like a super bike for a week
Started the ,running on 2 cyl. Again
Pulled checked the plugs they all looked dark and damp
A reader gave me a throttle valve # for my bike did an r&r no change
The regulater rectifier on occasion clicks ,I found a manufacturer and ask about its function he said that this unit would not cause the lack of performance , I am going to replace it any way
Thanks everyone for reading I have a few more things to check the pump pressure and the pressure regulater
  • Motor Head
12 Oct 2011 23:24 - 12 Oct 2011 23:28
#482849
The fuel injectors might be causing the problem. They can cause the rich running. There is a small screen at the Inlet to each injector. Bad fuel going through can cause them to not seal back up after the Electrical pulse. You can pull the Fuel Rail, so the injectors are hanging, and watch the Spray pattern, and also check to see if they Shut Off so no fuel flows. They can be cleaned and tested, I Highly Recommend This service For Old Injectors.
Have a look here at some info:
www.witchhunter.com/injectorvideo1.php4
Last edit: 12 Oct 2011 23:28 by Motor Head.
  • elfmagic17
  • elfmagic17's Avatar
13 Oct 2011 01:09
#482870
zelsdad wrote: Read , in this site about the unknown inline filter ,in fuel pump inlet.
Did you by chance recheck this filter again? maybe its plugged again?
Kenny Hicks
74 Honda CB550
  • MFolks
  • MFolks's Avatar
13 Oct 2011 01:33
#482874
If the one way return valve is clogged(it screws into the tank and a hose goes to it from the fuel pressure regulator), the bike will run rich.
  • jeffasaki
  • jeffasaki's Avatar
13 Oct 2011 01:59
#482875
change the fuel injetion
get rid of it
run a set of carbs
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
