New Member, 1980 750G in Memphis
  • mitchellsk
  • mitchellsk's Avatar Topic Author
08 Apr 2011 19:06 - 10 Apr 2011 21:48
#443461
New here from Memphis, found the link in DTT forums.
Picked up a 1980 750G yesterday for $260 with title. Nearly complete and needing some electrical attention and 25,000 miles.
After adjusting the points I finally got a very weak spark on one cylinder so I think the coils are shot. I found these new coils on ebay and the list includes my bike:
coils on ebay...
What do you guys think? Any experience with these?
RacecarMagazine.com
www.RacecarMagazine.com
1980 KZ750G Project
1969 Honda z50 running
1975 Honda 400f almost done
1978 Honda 750k running & driving
Last edit: 10 Apr 2011 21:48 by mitchellsk.
  • martin_csr
  • martin_csr's Avatar
Re: -
08 Apr 2011 20:01 - 12 Feb 2013 12:30
#443467
Last edit: 12 Feb 2013 12:30 by martin_csr.
  • mitchellsk
Re: New Member, 1980 750G in Memphis
08 Apr 2011 20:30 - 08 Apr 2011 20:31
#443468
Not sure but they look a little more than half the price of z1.
RacecarMagazine.com
1980 KZ750G Project
Last edit: 08 Apr 2011 20:31 by mitchellsk.
  • martin_csr
Re: -
08 Apr 2011 20:54 - 12 Feb 2013 12:21
#443474
Last edit: 12 Feb 2013 12:21 by martin_csr.
  • testarossa
  • testarossa's Avatar
08 Apr 2011 22:30
#443505
Hi Mitchell, welcome to KZR! I would suggest that you call Z1Enterprises before you pull the trigger on that ebay auction. As martin_csr suggested, the Dyna coils are an excellent replacement with really good customer service. I have seen a similar coil to the one listed sold in pairs for the 4 cylinder bikes at Z1E. Sometimes I don't find everything on their website, but they are always delightful to speak with on the phone, and can advise you of all your options as far as coils go.
However, before you go buying coils, use a multimeter and check that you are getting full battery voltage at your coil. It's quite possible that you have some faulty wiring that is leading to your weak spark. It's just one thing to rule out before you spend any money. You might be replacing a good coil, and still have the problem if there is just some corrosion on a terminal causing a low voltage condition.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • martin_csr
Re: -
09 Apr 2011 10:31 - 12 Feb 2013 12:22
#443608
Last edit: 12 Feb 2013 12:22 by martin_csr.
  • mitchellsk
25 Apr 2011 01:01
#446865
So after a lot of wire tracing and testing... it seems that the replacement ignition switch that the PO put on it isn't exactly compatible with the bike. Yes... it plugs right in to the harness but ONE important wire isnt getting any juice. I think after I either replace the switch or re-solder the wire my $260 bike will be a lot closer to starting B)
RacecarMagazine.com
1980 KZ750G Project
  • mitchellsk
05 May 2011 00:27 - 05 May 2011 00:31
#448970
So I soldered a couple wires across terminals on this wrong ignition switch the PO put on it so everything is getting juice that need juice now.
I set the timing and points, shot some starting fluid in and it started up on one cylinder after a few cranks.
I pulled the carbs off today and fiddled with the right carb and got it running on both cylinders now but it's going to need the carbs cleaned and rebuilt to be good.
My drag bars came in so I put them on. I took that gallon airbox out of the frame and put some pod filters on it that I had lying around.
I pulled the plastic inner fender out and it looks like I can chop several inches off the tail section to shorten it up a bit and make more rear tire visible and there are already tabs I can move the turn signals to.
Will post some updated pics when I get a chance but I have a plane ticket to Sacramento on the 16th and then will drive up to northern California with my girlfriend to visit some of her family and friends for two weeks. Then a road trip back to Memphis with camping along the way. B)
Oh ya, do you see that how the lower shock mounts are attached to chrome brackets attached to the swingarm? I don't see those on other bikes and wondering if they were added at some point to lower the bike and soften the rear suspension maybe?
RacecarMagazine.com
1980 KZ750G Project
Last edit: 05 May 2011 00:31 by mitchellsk.
  • mitchellsk
08 May 2011 21:16
#449709
Tail chopped off, drag bars added, replaced the airbox with pod filters, and removed the front fender.
Current as of May 8th:
As I got it:
RacecarMagazine.com
1980 KZ750G Project
