Just want to say THANKS!
  • jjack010
  • jjack010's Avatar Topic Author
05 Apr 2011 23:35
#442895
I've been coming to this site off and on for several years now. I've been turning wrenches since I was able to, but it was usually on a figure 8 race car or other 4 wheeled vehicle. So since I've become a proud owner of a molested Z1, :woohoo: I've started learning a wealth of information about working on these bikes. All in all, principles are the same between working on carb'ed bikes and cars, but then again there are so many differences. So, I have about a month and a half before I ship out again and my mission is to get the bike road worthy and get some miles on it before I leave. BTW, I'm active Army. With all that being said, I just want to say thanks for all of the valuable information! I just checked valve clearance for the first time. Then I stumbled on to the article about using a zip tie instead of the valve hold down tool. AWESOME! First time GO. Until next time..............
Greetings from Central Texas
1974 Kawasaki Z1
Central Texas
  • Stu Pidasole
  • Stu Pidasole's Avatar
  • if you aint mod'n, you aint rock'n!
Re: Just want to say THANKS!
05 Apr 2011 23:44 - 05 Apr 2011 23:46
#442897
Awesome and thank you. Be safe. Joe
Last edit: 05 Apr 2011 23:46 by Stu Pidasole.
  • trianglelaguna
  • trianglelaguna's Avatar
06 Apr 2011 00:55
#442914
link the zip tie article if you get time..or the words your searched to find it....
thanks for your service...be careful and come home soon
Craig
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • wireman
  • wireman's Avatar
06 Apr 2011 01:13
#442916
Keep your powder dry B)
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
06 Apr 2011 04:06
#442931
Thank you Jack!
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • jjack010
06 Apr 2011 08:02
#442936
Found the zip tie info here - kzrider.com/forum/2-engine/431091-poppin...inder-w-video#433450 . I also had one valve where the shim was to tight and I didn't have enough clearance to remove the shim. I attached some duct tape to the end of the zip strip just to give a bit more clearance. Worked great. Make sure the tape is secured well so when you pull the zip strip out, it doesn't fall off into the combustion chamber.
1974 Kawasaki Z1
Central Texas
  • testarossa
  • testarossa's Avatar
06 Apr 2011 08:24
#442941
Thanks for your service!
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • jjack010
06 Apr 2011 10:47
#442960
No problem. Thanks for the greetings.
1974 Kawasaki Z1
Central Texas
