New to the site
- Dads79KzLTD
New to the site
28 Aug 2010 16:24
Glad to be part of the group. I decided to join this group because of my Dad. He bought a 79 Kz1000 new and he passed away in December. As a tribute, I want to restore his bike which has been sitting in the barn for about 25 yrs. I am in Afghanistan with the Army for about 6 more months then I get to begin on my project. Cant wait to put pictures up as the project begins. Any ideas will be much appreciated.
- Kawickrice
Re: New to the site
28 Aug 2010 16:35
First off Thank You for your service, and come home safe.
You can get all the info for what ever you want to do to the bike right here, good group of Kaw lovers. Your Dad would be proud to know you are planning to get his bike going again, I am sure it meant alot to him or he would not have kept it for so long. Do you plan on bringing it back stock?
Oh by the way, welcome to KZR soldier
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Dads79KzLTD
Re: New to the site
28 Aug 2010 16:48
I think I want to bring it back stock. I know it needs a new seat, and I think the baffles in the pipes are rusted. Fortunately, quite a few guys in my unit are bikers and have given me some insite. I found a seat on ebay, and also a set of pipes. Just have to make sure that the carbs are jetted properly for the new pipes. My squad leader also is good friends with the Patriot Guard Riders in our area so I have a good source of help there. The bike was special to my dad and I have many fond memories of riding it with him as a kid. I hope my boys will have the same opportunity. Thanks to the folks who made this group of people. I had no idea how many people love the old Kz's as much as me and my Dad. Its awsome.
- hocbj23
- Visitor
Re: New to the site
28 Aug 2010 17:17
Lots of folks here that know lots about the old KZs.Watch out for a coupla weirdos named Plummen and Old Man Rock though.They know a lot of stuff but-well-you know-they are getten on in years and sometimes they just lose it.Lol.Welcome to the site.bj
- lilhatchet
Re: New to the site
28 Aug 2010 17:18
From one soldier to another welcome. Your Dad would be proud. I just got my first KZ as well and have it posted in projects. You should do the the same when you get back. Look forward to seeing your bike be brought back.
1996 KZ100 Police
- MFolks
Re: New to the site
28 Aug 2010 17:24
This will help a lot when it's time to clean the carbs:
Carb Cleaning 101
By M. Shively
The elements of internal combustion engines are: correct fuel/air ratio, spark at right time, and adequate cylinder compression.
There are many passageways and openings to check and clean. All are important in function and when obstructed or not working properly, have subtle to radical effects on engine performance. Vacuum leaks and carburetor synchronization also effect performance and should be inspected and adjusted following the below procedures.
Warning: Remove all rubber parts before you begin. These parts usually include vacuum diaphragms, needle valves, o'rings, hoses, and other parts. Spray cleaners will damage these parts. Do not disassemble individual carbs from the carb bracket.
Air & Fuel Passageways: Trace and learn individual fuel and air circuits from beginning to end. Machines can only drill straight through the cast passageways. To change direction, another angled passageway must be drilled. The union is plugged with a brass or bronze bead. Inspect and clean each passageway with spray cleaner, brushes/pipe cleaners/etc, and compressed air. Remove any discoloration and debris. Look for spray cleaner to exit from one or more passageways.
Jet Cleaning: Inspect jets by holding to light and look through them. You should see an unobstructed round hole. Clean the jets with one or more of the following: jet cleaning wires, soak solutions, carb spray cleaners and compressed air. Re-inspect jets after cleaning and install when clear of obstructions. Some main jets have paper-like gaskets. Most have metal spacers between the jet and the emulsion tube. Some screw directly into a brass emulsion tube which is machined for a 7mm wrench at its float chamber exposed base.
Inlet Fuel Valve: Inspect the needle valve & spring. Press down the tiny metal rod that protrudes from the butt or float end of the needle valve. The spring should move freely and return the rod to its location. Check the needle valve's seat area for a groove or other wear. It should appear highly polished. Some needle valve seats are rubber and wear may not be visible. Inspect the needle valve jet seat. You can clean the jet seat with Q-tips and semi-chrome polish if necessary.
Carb Body Castings: Blow air through the atmospheric vent holes located on the dome of each float bowl chamber. Air should exit via hoses or brass nipples. Inspect the emulsion tubes and passageways (cast towers that jets thread into) for discoloration and debris. Clean interior emulsion towers with a soft bristle gun cleaning brush. Clean each Venturi (main carb bore).
Needle Jets & Jet Needles: Clean the needle jets, jet needles, and passageway or tower that needle jet screws into. Clean the emulsion tube (pipe between needle jet and main jet) (Main Jet may screw into emulsion tube). Jet needles are part of the throttle slides. See below…
Throttle Slides: There are several types of throttle slides: Mechanical linkage, vacuum, diaphragm, and cable. Disassembling the jet needle from the slide is not always required for cleaning. If you have vacuum piston type throttle slides (large diameter solid metal slide), avoid cleaning the lubrication from sides and caps. If piston type check cap vents and passageways with air. Clean if necessary and re-lube. If you have rubber vacuum throttle diaphragms, inspect for dry-rot, defects, and tears by gently stretching rubber away from center. Do this until all areas around diaphragm have been inspected. Replace any defective part as described above. Clean carb body areas around diaphragm including air passageways and air jets. Diaphragms have a locator loop or tab fabricated into their sealing edge. Observe this locator upon reassembly. Avoid pinching the diaphragm when reinstalling caps.
Fuel Screws: Fuel screws have sharp tapered ends. Carefully turn one fuel screw in while counting the turns until it seats lightly. Warning: These screws are very easily damaged if over tightened into their seats. Record amount of "turns-in" and remove the fuel screw, spring, washer, and o'ring. The fuel screw is part of the enrichment (choke) circuit...clean passageways as described above. When carbs are assembled, spray low PSI compressed air into diaphragm air vents located at intake side of carbs. Throttle slides should rise, then fall when air is removed. Lightly lube external moving linkages. Reinstall carbs and follow through with carburetor synchronization.
Throttle Cables: Lubricate cables periodically. If cables are disconnected from carbs or removed for replacement, etc . . . remember cable routing and ensure proper reinstallation routing. Avoid bread-tying, sharp bends, and pinching cables. Adjust cables so throttle grip has about 5mm of play or throttle slides or butterfly valves may not open completely (full throttle)(wide full open).
Float Bowls: Inspect float bowls for sediment, gum or varnish, crystallization, and defects. Clean all pipes, tubes, passageways, and embedded jets with cleaners and compressed air. Remove and clean the drain screw and area. Inspect bowl gasket and replace if necessary. Clean and inspect overflow pipes and tubes, look for vertical cracks.
Floats: There are several types of float materials: plastic, brass, black composite, tin, and others. Handle floats carefully. Avoid bending, twisting, denting, or other means of mishandling. Most floats are adjustable by bending a small metal tab near the float axle end. Do not change the float adjuster tab unless tuning fuel service levels. Clean metal floats by soaking or by spraying cleaner and wiping clean. Other material type floats may require replacement if cleaning is necessary. Inspect the needle valve (float valve) and seat. Check needle valve's spring loaded pin. It should depress and return smoothly and without resistance. Check the needle valve's tip for a worn groove. Replace needle valve and seat if either symptom exists. These parts wear together and must be replaced as a set.
Synchronization: This is a fine adjustment performed usually and preferably with the carbs installed and the engine running. The unusual part is performed with gauged wire with the carbs on the work bench. Carburetor synchronizing balances Venturi vacuum at the exhaust side of each carburetor, resulting with smooth idling and optimized performance at all throttle openings. Synchronization is checked using a set of gauges which are either air vacuum type or liquid mercury type. The gauges are connected to vacuum ports on the intake manifolds via nipple tubes or if sealed with screws, sync gauge adapters will be needed. With the engine running at temperature, and with a fan or means of forced convection aimed onto the engine, the carbs fuel screws and idle are adjusted, then the synchronization is adjusted via adjustment screws on the carbs. A reserve fuel tank is recommended for convenience of accessing carbs during this procedure. See gauge instructions and repair manuals for detailed use of synchronization gauges.
Notes: While carbs are apart, record the jet sizes. Look for a very small number imprinted on the body of the jets. Verify that numbers are the same for all jets on models with in-line cylinders. A few transverse-4 models and V-engines, the inner and outer carbs use some different size jets and it's important to not mix them up. If you have dial or veneer calipers, measure and record float heights. Perform measurements with floats just touching needle valves, though not depressing the needle valve rods. Replace fuel and vacuum hoses. Be sure to use fuel rated hose for fuel. Install or replace in-line fuel filters. It's a good time to remove and clean interior petcock fuel filters. Inspect carb manifolds for dry-rotting, inspect all clamps and air ducts. Inspect, clean, lube, and/or replace air filter(s).
Before attempting to start the engine, remove the sparkplugs,spray in the holes some PB Blaster or Marvel Mystery Oil, re-install the plugs, and let sit for at least 5 days.
After that time is up, remove the plugs, remove a CD sized cover on the right side of the engine and using a 17mm wrench on the fake "Nut" on the crank shaft, turn the engine over a few times.
Install a fresh set of NGK B8ES or Denso W24 ESU sparkplugs gapped between 0.028"-0.032" and see if the engine will start.
Hopefully the gas tank is not too rusted internally, but I've got some cleaning information about that too if you need it.
Carb Cleaning 101
By M. Shively
- MFolks
Re: New to the site
28 Aug 2010 17:29
- roy-b-boy-b
Re: New to the site
28 Aug 2010 18:05
Thanks for serving.
Read all you can while you have a chance. That will help a lot.
I sold a "80" LTD to a soldier while he was stationed where you are. He's here now in Ft. Campbell.
Keep safe. Roy
Keep safe. Roy
- testarossa
Re: New to the site
28 Aug 2010 22:01
Welcome to KZR! Thank you for your service to our country.
I love your idea, and I know that your father would be proud. Best wishes for you and all the members of your unit. Stay safe, and get home in one piece so you can send us some pictures of that LTD.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- Old Kaw Boy
Re: New to the site
29 Aug 2010 04:58
Thanks for Serving.
This is by far the best site for bringing back the old Kaw's. Keep us posted on your progress.
Good Luck!
1979 Kawasaki 1000
Good Luck!
1979 Kawasaki 1000
OLD KAW BOY
1979 LTD 1000
1979 LTD 1000
- PLUMMEN
Re: New to the site
29 Aug 2010 05:53
hocbj23 wrote:
keep your head down and keep your powder dry young man,see ya back here soon! heres a motivational poster for ya,kept me going back in the day! :woohoo:
welcome to z-jungle,too many parachute malfunctions when i was younger is my excuse (not sure what bjs is! :woohoo: )Lots of folks here that know lots about the old KZs.Watch out for a coupla weirdos named Plummen and Old Man Rock though.They know a lot of stuff but-well-you know-they are getten on in years and sometimes they just lose it.Lol.Welcome to the site.bj
- hocbj23
- Visitor
Re: New to the site
29 Aug 2010 07:00
8 years in the 82nd Airborne Division.They kept telling me to land on my feet,but my head kept getting in the way.Lol.bj
