ignition switch
- painfulink333
ignition switch
06 Jul 2010 14:51
hi i had to go and buy a new ignition switch due to the fact that while i was at the laconia bike week celebrations ....on the ride home i hit a huge pothole which caused my keys in the ignition to jump out and i didnt realize this till i was well out of the area it happened in ...long story short i had to use a screwdriver to get the bike started when i shut it off for gas ...any info on somewhere to get schematics for the igniton so i can put it in this week ...i had a site that showed all the schematics but forgot how to get there :S thanks for any help
1977 kz650
- TeK9iNe
- What did you do!?!
Re: ignition switch
06 Jul 2010 15:27
OK, so... what bike?!?
kawasaki.com has parts diagrams.
electrical schematics can be found here in the filebase for most models.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- painfulink333
Re: ignition switch
06 Jul 2010 18:15
hi i have a 77 kz650...thanks for the info ill let you know if it was helpful tomorrow after i try installing it ..it looks pretty damn simple ...plug and go
1977 kz650
- Old Man Rock
Re: ignition switch
07 Jul 2010 05:29
I just replaced mine with a Z1 ignition switch on my KZ900...
NOTE: This will be a 6 conductor plug end but as in my 900 wiring (4 conductor plug) it inserts into the 6 pin connector... Continuity test, rotated switch, paired conductors check continuity... All good...
As you stated, plug and go....
Just in case you need...
www.z1enterprises.com/SearchResult.aspx?...ds=ignition%20switch
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
Re: ignition switch
07 Jul 2010 05:29
www.z1enterprises.com/detail.aspx?ID=369
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
