choke issues
  • painfulink333
  • painfulink333's Avatar Topic Author
choke issues
15 Jun 2010 14:44
#375924
hi im new here ...just picked up a 77 kz 650...33,000 miles on her ...i rode her for about 150 miles ...no issues at all she ran well ...idled at 1500rpms no problem ....put her away for the night forgot to shut the gas off ....when i fired her up with the choke on she seemed ok til i went to shut the choke off ..when i did she just up and died ...the issue i have is i had to ride her back the same 150 miles to go home ...i had to keep the choke on about a third of the way and she still was wanting to stall on me if stopped at a light .....the guy i bought her from had just had the carbs rebuilt ..and had a few issues with it running a 4 into 1 exhaust ...he switched it back to 4 into 2 ...any suggestions here ????thanks brian
1977 kz650
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: choke issues
15 Jun 2010 15:53
#375934
Sounds like you could have some debris in one or more of the pilot jets.
They need to be super shiney clear al the way through.
GL.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Re: choke issues
15 Jun 2010 16:22 - 15 Jun 2010 16:30
#375944
Hello, Brian, and WELCOME to KZR! :)
We're glad you're here! :cheer:
Hoping an in-line fuel filter is fitted.
Dual fuel lines need two in-line filters.
In-line filters are inexpensive and readily available through Z1E, bike shops, etc.
Click > In-line fuel filter from Z1E
Crud or grit already in the float valve may sometimes be successfully flushed out, without needing to remove the carbs.
Crud or grit in the pilot jets as suggested by TeK9iNe, will likely require carb disassembly to access and clean.
Good Fortune! :)
Last edit: 15 Jun 2010 16:30 by Patton.
  • painfulink333
Re: choke issues
17 Jun 2010 14:46
#376376
hi i posted about the choke issue i was having and such you said something about adding a fuel filter ...i looked and there wasnt one ...and i only have one gas line coming from the tank to the carbs ...should i have two???
1977 kz650
Re: choke issues
17 Jun 2010 16:23
#376411
One fuel line is correct. Ed
Re: choke issues
17 Jun 2010 16:23 - 17 Jun 2010 16:28
#376414
Some carbs are fitted with two fuel intake nipples, while other styles have a single fuel intake nipple.
Am thinking the 1977 KZ650 carb has a single fuel intake, which would mean a single fuel line running from the petcock to the carb intake nipple.
The in-line fuel filter should be fitted into the fuel line somewhere between the petcock and carb.
There's an "arrow" on the in-line filter showing direction of fuel flow through the filter.
Good Fortune! :)
Last edit: 17 Jun 2010 16:28 by Patton.
  • painfulink333
Re: choke issues
17 Jun 2010 19:12
#376484
thanks for the info i got a filter and will be installing it tomorrow ...i will be taking the bike on a ride on saturday from mass. up to new hampshire for the end of bike week in laconia ....B) ill let you all know how she runs and such after the trip ....i will also be posting some pics of us ...on monday
1977 kz650
Re: choke issues
18 Jun 2010 03:01
#376537
Might consider using Kroil carb cleaner before and during the ride. It's mixed with fuel inside the tank, and sometimes helps clean the carbs internally while riding.
There are several brands of carb cleaner, but Kroil is favored by many folks.
Good Fortune! :)
