Hello from Holland
  • T_Dub
  • T_Dub's Avatar
Re: Hello from Holland
14 May 2010 12:32
#367914
Welcome Michel!
This may be a silly question but I have seen it too many times. Do you have fresh gas in the bike? And have you had a look at the plugs? Like Tim said, a good carb clean is in order, but fresh gas can always help if the stuff in your bike has been sitting a while.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • kusanagi
  • kusanagi's Avatar Topic Author
15 May 2010 07:23
#368088
Thanks for the tips. Took out the carbs today and sprayed carb cleaner in every hole I could find. Also used some copper wire to test a few holes.
Tomorrow I will try to rebuild the carbs into the bike and give it a try :S
Keep you posted!
  • kusanagi
16 May 2010 08:51
#368259
Moved it overhere:
kzrider.com/index.php?option=com_kunena&...d=3&id=368256#368256
FYI, still doesn't start but that has probably to do with my knowledge.
I let some gas leak in the carb air intake and then it ran for a few seconds quit nicely.
So I still assume a carb issue. Posted some pics of teh carbs in above thread.
Thanks so far
