Hello from Holland
- kusanagi
Hello from Holland
09 May 2010 12:31
Hi,
New member signing in
Just bought my first Z750 E1. Enjoyed my first ride a few days back. Running into some issues which I will post in the respective areas
Hope I will gain a lot of knowledge on your forum.
Cheers,
Michel
Cheers,
Michel
- Iron Duke
- what are you rebelling against?
Re: Hello from Holland
09 May 2010 13:45
Welcome Michel, this be the place for questions and answers about Kawasaki's, regards Duke
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
- Mcdroid
- Gone Kwackers
09 May 2010 15:19
Welcome Michel...if you have questions, we have answers...not necessarily good or correct, but answers nonetheless
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- mart13
- hocbj23
09 May 2010 16:24
welcome.lots of folks here with lots of expertise.I am sure u can find answers to ur questions/issues.bj
- trianglelaguna
09 May 2010 19:28
cool..welcome
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- RaeRae
- Smart @ss white girl!
10 May 2010 12:52
Welcome aboard!
Rae
OWN:
82 KZ550 LTD (work in progress)
81 550 GPz (work in progress)
81 KZ550A (parts bike)
91 750 Honda Nighthawk
WANT:
One in every size and color!
Euharlee, GA by way of Glendale, AZ
WANT:
- kusanagi
11 May 2010 04:55
Thanks for the warm welcome
If I may ask a question here (?) I have a typical issue with my Z750:
My Z750 is a smooth runner... if she starts at all.
The only way I have got her running is with a charger connected to the battery as it takes a few minutes of fiddling to get her running.
When she is standing for a few hours and I attempt to start her she immediately fires up... for 1 second and then dies out.
Can't get her back on after that. Nothing no rumbling in the negine, just plain spinning startermotor and that's all.
What would be the logical way forward?
I must admit I did some reading already, so using some carburator cleaning and checking the sparkplugs would be a good idea according to other members.
If this is not the right place for the question, which forum would? Engine or Electrical??
Hope to get some clues from you guys
- rstnick
11 May 2010 06:45 - 11 May 2010 06:46
Welcome Michel.
Also from Holland here, now living in Canada.
The engine section would be fine as your having trouble starting yours.
Did you make any changes to the air filtering system?
If so, changes to the carbs will be needed.
A good cleaning of the carbs is all that may be necessary, paying close attention to the choke/enricher system.
Clean air filter is a good start as well.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 11 May 2010 06:46 by rstnick.
- kusanagi
11 May 2010 09:18
Thanks for the reply. All is still original.
Want to have the bike working first before I start to change things. Troubleshooting is a nightmare if you start from an unknown point and change too much at the same time.
If the bike is running, i would like to strip it down to a superbike style kinda thing. So will need help later with the carburators later
Found some carburator cleaner in an old cabinet. Will get working on the bike Thursday. Keep you posted.
- kusanagi
14 May 2010 03:22
It runs well on carburator cleaner. A bit rough and loud but it runs. It still doesn't run on petrol though. Took the carburators out and the look clean. Suggestions where to start looking? (can I use carburator cleaner from Wurth on a non running engine/carburator?)
- timebomb33
14 May 2010 07:53
wurth carb cleaner in the can is a very good product i have used it quite abit in the past it sounds to me like you have plugged pilot circuits passages and jets, remove them let them soak in the carb cleaner for a couple of hours remove the slides and any other rubber componets as well and try not to get to much carb cleaner on them. spray the cleaner into every port and passage and then use a rubber tipped blow gun and compressed air to completly blow thru all the same passages that you just sprayed carb cleaner thru. make sure you get good airflow thru them then reassemble and give it a try you should be good to go if you can't get air flow i use copper wire to try and force out the blockages. good luck and welcome
I THINK MY POWERBAND BROKE
