hello ,from the united kingdom
  • run990
  • run990's Avatar Topic Author
  • too old & creaky to be messing with bikes
13 Apr 2010 11:30 - 13 Apr 2010 12:14
#360371
hi i have just resurected a 81 750 ltd .great straight original bar a 4into1 exhaust .
i am situated in lancashire in the united kingdom .
i hope topost some pics etc ,however i am trying to sort an anoying rattle when on the side stand ,see my post on the engine section.the rattle is very bad when it starts you thing someth
ings going to give ,blip the throttle & it quitetens down to normal .sounds like a chain flailing about ready to snap.
any ideas i have checked the obvious & sump is clean no debris etc,i have changed the starter clutch.i wonder if it could be the primary chain but it was within specs.
1981 kz750 ltd
bad back
arthritic arm
no money
could not be happier .
Last edit: 13 Apr 2010 12:14 by run990. Reason: added some pics of my bike
  • ltdrider
  • ltdrider's Avatar
Re: hello ,from the united kingdom
13 Apr 2010 11:39
#360373
Welcome to the site.
Have you tried to adjust the timing chain to eliminate the rattle?
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
  • run990
13 Apr 2010 11:56 - 13 Apr 2010 12:16
#360377
hi mate ,ihave tried to ,however bike has a silly self adjuster 2 wedges & a spring .i have packed the spring & checked tension with the cam cover off ,seemed ok but the tensioner has no locking system so can back off .i am going to modyfy a spare tensioner i have to make adjustable with a bolt & lock nut.
thanks for the reply .
1981 kz750 ltd
bad back
arthritic arm
no money
Last edit: 13 Apr 2010 12:16 by run990. Reason: another pic
