Howdy, All.
  • schmedly
  • schmedly's Avatar Topic Author
Howdy, All.
12 Apr 2010 12:16
#360143
I am about to start restoring a 1982 GPZ 550, and this looked like a good place to start nosing around. It has not run for about 17 years. It has been stored indoors, so it looks pretty good.
I currently ride a 1982 Suzuki GS 850. I also have a 1980 Honda CB 650 my wife is supposed to ride, but doesn't. I used to ride expensive baggers (2003 HD FLHTCI and a 2008 Yamaha RSTD) but these old bikes of Nippon are just as fun and way cheaper. When I get the GPZ running it will belong to my friend, but he will let me ride it.
Looks like I will need a gas tank. The old one has a bad scratch and rust inside. Maybe I should paint and reseal it. Will see. Decal is messed up though.
Carbs probably need to be replaced or rebuilt, I assume.
Also two rear turn signals busted off, and new tires for sure. Motor needs to touch up paint but supposedly it ran solid when parked.
I am just a weekend garage mechanic so any pointers and wisdom will be welcomed.
Is there any line on used parts here? Thanks, and see you around.
  • Mark Wing
  • Mark Wing's Avatar
Re: Howdy, All.
12 Apr 2010 12:48
#360149
Welcome to the site, I'd say start with changing ALL fluids and a carb re-build, check the valve clearance and the cam chain adjustment most likely the rubber is bad. Parts and a factory manual can be found on eBay. The tank can be cleaned and repainted and decals can be found on the link.
Mark
www.reproductiondecals.com/default_frame...html?kaw_3.html~main
Yorba Linda Cal.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Howdy, All.
12 Apr 2010 14:19
#360161
Welcome, and you probably know the source of all used parts...eBay...not much on this site although you can periodically check the Classified section above. There used to be a GPz550 site but I think it has gone belly-up for lack of interest...there are a few GPz550 owners on KZR and maybe they'll chime in with more current info. I suppose you are active on the GS site?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • stardon
  • stardon's Avatar
Re: Howdy, All.
12 Apr 2010 14:56
#360166
I AM HERE!!! I did a frame-up restore on my 1983 GPZ 550. Mine, like yours sat in a garage for 15 years. Unfortunately, the garage didn't have a roof. The tank was trash because of the 15 year old gas and the carbs had to soak for days in carb cleaner to clean them out. There was a fair amount of rust and corrosion but it all cleaned up. I did all the painting myself. I used DP40 primer, Ditzler AE paint (catalyzed) and clear coat. It took me 2 years of working on it after hours to get it back together. It is now such a sweet ride I don't think I'll ever get ride of it. Where are you located at?
  • Iron Duke
  • Iron Duke's Avatar
  • what are you rebelling against?
Re: Howdy, All.
12 Apr 2010 16:58
#360182
David, (and all other new gpz 550 owners ) Welcome if its a Kawi, it is known about here,lota help,great fellowship, why cause we all love our Kawis big uns, small ones,and in between ones. regards Duke
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
