KZ900 LTD Rebuild
  • DPH900
  • DPH900's Avatar Topic Author
KZ900 LTD Rebuild
27 Mar 2006 20:23
#34823
Not sure how this all works yet--but am anxious to learn.
This seems to be the site for a novice like me who needs expert around for help. I am looking to rebuild the KZ900 LTD that I bought for $1.00. I figure it was a deal. Once I cleaned the carbs the started right up.
I ran it for about a year and just felt like tearing it apart and building it out clean.
I have got it down to just the engine--and am scared to start--I have never opened an engine before, but figure its time to learn.
I don't even care what it costs me. Any advise on what to read or where to start?
I have attached what it looked like at the start
Post edited by: DPH900, at: 2006/03/27 23:26
  • wireman
  • wireman's Avatar
Re: KZ900 LTD Rebuild
27 Mar 2006 20:30
#34825
$1.00 huh?ill give you $2.00 without even seeing it run,double your money!:laugh: where are you located,and how did it run before?
  • DPH900
27 Mar 2006 20:32
#34826
I am in SLC,
The bike ran rich--I had someone work on the valves to see if we could lean it up a bit--but it never helped. We even tried running without the filter. No luck. So I just kept running it and changed to plugs ever few weeks or so.
I am going to stick this in the "Engine" part of the site. Looks like thats the place to start.
Post edited by: DPH900, at: 2006/03/27 23:36
  • wireman
  • wireman's Avatar
27 Mar 2006 20:40
#34828
try running a compression check before you tear motor apart if the motor is still solid you can concentrate on fixing the brakes /suspension and other cosmetic stuff after 30 years these bikes tend to loosen up a lot of stuff and it will be easier on you to not have to go through motor first time if you dont have to.just run a compression check,if its close check your valve clearances and scrub motor up real good.running rich is probably a carb problem.goodluck,happy wrenching!;)
  • DPH900
27 Mar 2006 20:45
#34834
Thanks--Ill start there
  • donthekawguy
  • donthekawguy's Avatar
27 Mar 2006 21:45
#34853
Are you running it without filters? Also a four inot one will require rejetting. But it should be running lean. Pull the carbs and see what main jets you have and contact wiredgeorge. He is the carb master and has a web site.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • ltdrider
  • ltdrider's Avatar
28 Mar 2006 12:28
#34979
DPH900, you are my HERO.
A 900LTD for $1.00??!!
You need a shop manual. Even if you don't want to do major engine work yourself, you should have one.
SLC.... Salt Lake City? I had to wrack my brain to come up with a city that fit those initials.
Send me a PM if you want, tell me what you have for maint. manuals, I'll help with your library if you need it.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
