New from Minnesota here...
  • jared3377
  • jared3377's Avatar Topic Author
10 Dec 2009 23:39
#338475
Hello All!
My name's Jared, and I just bought an '82 Kawasaki KZ750 LTD two days ago. Finding it for a good deal, I jumped on the chance to snap it up--HOWEVER, being in MN, I can't ride the darn bike until at least March and more likely April. It's going to drive me crazy, but it gives me something to look forward to. I'm attaching a picture, but it's not that good of one--feel free to check it out, and I'm very grateful to find this site!
Jared
  • Iron Duke
  • Iron Duke's Avatar
  • what are you rebelling against?
Re: New from Minnesota here...
11 Dec 2009 00:08
#338476
Hello Jared, Welcome to KZR nation,good to have another Kawie owner on board. Its going to be 37-40 here this saturday if it is and the pavement is clear of the 8+ " of sno I'll try to ride. used to live in N.D. so know what the weather is like in north country,picture did not make it,AND we need pictures.The invasion continues. regards Duke
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
11 Dec 2009 03:08
#338479
Welcome Jared...try again with the photo thing...takes a bit to get the hang of it. :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • TerryK
  • TerryK's Avatar
11 Dec 2009 07:02
#338491
Welcome Jared! Where in MN are you?
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
11 Dec 2009 07:27 - 11 Dec 2009 07:28
#338497
Welcome!
To up a picture:
In the "select image file to attach" box, browse to the picture on your hardrive. Click ok. Then it will display the location of the file in this box.
Now click anywhere in the text window to place the curser where you want the image to appear in your message.
Then click in the "[ img ]" buton beside the "Browse..." button beside your file location.
The "[ img ]" will then appear in the text window and when you click submit or preview, you will see your image in its place.
Good luck!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 11 Dec 2009 07:28 by TeK9iNe.
  • Link14
  • Link14's Avatar
11 Dec 2009 08:17
#338507
Hey Jared, glad to have another '82 750-4 around. I got mine in the winter a couple of years ago too. Mine barely ran so I spent the time during the cold weather to do a couple of things (after I got the Factory Service Manual!)
1. Pulled the carbs apart (not off the rack though) and gave them a thorough cleaning and new carb kits.
2. Went through the entire wiring harness and cleaned up all the connections.
3. Flushed the brakes with new brake fluid
4. Replaced the front fork oil. I ended up replacing the seals too 'cause mine were leaking.
5. Replaced the fuel lines and added a fuel filter.
6. Changed oil and filter
In hindsight, I should have also checked my valve clearances. Mine bike only had 12k miles on it, but I found out later that summer that 6 of 8 shims were out of spec. Since these are under bucket shims, I had to pull the cams to figure out the sizes, then order shims, then sweat over the reinstallation that everything went back correctly. A couple of weeks work for a newbie during the middle of prime riding season...should have done it in the winter.
Have fun and stay warm!
