Hello from Bulgaria
- kpower
13 Aug 2009 01:52 - 13 Aug 2009 01:54 #313548
by kpower
1978 KZ650 - B2
Hello from Bulgaria was created by kpower
hi dudes,
just want to say Hi to everybody
I just bought a KZ 650-B02 but on the side cover writes Z650 it's strange because it is 1978 bike...
here it is:
it have some remark's, but runs like a charm, actualy it start's to run after 120 km/h :woohoo:
can you give me advice, after 20-30 km ride, oil light start's to flash on idle speed /even 1500rpm/ it stops around 1800rpm. I measure Oil pressure when engin is warmed is OK, oil is 15W50 with new oil/air filter... is it possible to overheat the engine?
Best Regards
Krasi
here it is:
Best Regards
Krasi
1978 KZ650 - B2
Last edit: 13 Aug 2009 01:54 by kpower.
- Russ Jackson
- Thank you received: 1
13 Aug 2009 05:22 #313561
by Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Replied by Russ Jackson on topic Hello from Bulgaria
Welcome to the site. Nice clean bike. ...Russ
- kpower
- Mcdroid
- Gone Kwackers
- Thank you received: 316
13 Aug 2009 08:11 #313593
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic Hello from Bulgaria
Welcome Krasi...nice to see other older Kawasaki's from others parts of the world. Do you know where your bike was imported from? I am guessing that it was originally from western Europe (Germany, France, etc.) before it found you.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- N0NB
- Blue handles better
13 Aug 2009 08:45 #313608
by N0NB
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
Replied by N0NB on topic Hello from Bulgaria
Hi Krasi. Nice 650.
Regarding the light, the best way to know is to get a real pressure gauge on it and see what the pressure is. The electronic sender located under the points cover can fail and give a false indication. The cheap fix is to rob a sender from a bike in the junk yard and see if the light comes on as before.
I'm guessing you have heavy enough oil, maybe too heavy, but that would seem to cause the light to come on when the engine is cold. I've seen electronic senders fail once they get hot on other engines so I'm guessing that is your most likely source of the problem but knowing the actual pressure will give you piece of mind.
Good luck!
Good luck!
Nate
- kpower
13 Aug 2009 12:00 #313703
by kpower
1978 KZ650 - B2
Replied by kpower on topic Hello from Bulgaria
thank's for warm welcome
Michael the sales man says that tha bike is imported from Italy and is on 32k km...
Nate, I'll try with other gauge /this one I've made from old oil pressure meter from car nut wokr's fine / the light comes only after 20-30 km ride.... in service manual says that oil pressure 4000rpm @ 90 degrees oil temperature /i think that temperature is higher/ has to be 2.0-2.5 kg/cm2 (28-30 psi) it is around 28psi...
I'll chek oil pressure switch
cheers
cheers
1978 KZ650 - B2
- hoghaterkaw
13 Aug 2009 15:59 #313747
by hoghaterkaw
Replied by hoghaterkaw on topic Hello from Bulgaria
Welcome to this madhouse.:laugh: Kawasaki's imported to Europe were not labled as "KZ" they were labled as "Z".
- Iron Duke
- what are you rebelling against?
13 Aug 2009 21:05 #313797
by Iron Duke
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
Replied by Iron Duke on topic Hello from Bulgaria
Kpower,welcome to KZR Nation,or Z-jungle nice looking 650,Nate is close to right,again welcome, the invasion continues. regards Duke
1982 KZ550 LTD C-3
- bill_wilcox100
- Thank you received: 5
13 Aug 2009 23:04 #313816
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic Hello from Bulgaria
kpower, welcome to the KZR Nation. Great to have you here with us.
Great looking bike... great shape.
I think you are in for many seasons of great riding.
Best of success.
Bill
Best of success.
Bill
Upgrades:
Montreal, Canada
