New owner, 1981 Kawasaki 750 LTD
- azr
20 Jul 2009 23:41
Big hi to everyone out there. Looks like a great site. I'm off in a few days to pick up my first Kawasaki, she an 81 750 LTD. She looks in great shape, and hopefully runs as good. New to Kawasaki and am looking forward it. I'll post pictures on my return. Hey I'm wondering what things are typically good to worry about with the Kawasakis when getting an new bike to you.
1980 KZ750E
- GPz550D1
Re: New owner, 1981 Kawasaki 750 LTD
21 Jul 2009 05:50
Just a few things for you to consider would be to check the valve clearance and do an oil and filter change. I would inspect/replace the air filter and spark plugs. Check water level in battery and charge, if needed. You should have electronic ignition on your bike, but you will want to take out the mechanical timing advancer and lubricate it. Those are just a few things.
Robert
Robert
1981 KZ550-D1
- Link14
21 Jul 2009 06:28
Hi AZR, welcome to the site. If the bike runs well, I'd change the oil/filter/plugs and clean air filter (like GPz recommended). Depending on if the bikes been run alot maybe flush out the gas tank with new gas.
If the bike runs rough or not at all, I'd start with valve clearances and cleaning the carbs...those were issues on my 750. Also, if you need an electronic copy of the Factory Manual (the best), you can go to Wired George's Tech Forum at www.wgcarbs.com and he has a download section with the manual in it.
Good Luck
Good Luck
- azr
21 Jul 2009 10:36
Thanks for the info. If I can get that manual that will be perfect.
1980 KZ750E
