just bought a 81'kz1100
  • Tedster
  • Tedster's Avatar Topic Author
17 Jun 2009 19:25
#300036
HI
my name is ted i am new here i already put a post under engines,i picked up an 81'KZ1100 it is a pretty clean bike got the bike home put a new battery in it,took the carbs off to rebuild them this bike has been in garage for a little while,has good compression 118 to 122# in all cylinders,now the bad the tranny will go into 1st and nuetral but will not shift into any up gears,i took the side cover off and cannot visually see anything wrong i sure hope the case don't need to be split,i would like to know where to buy complete rebuild kits for the carbs to,
any help will be appreciated
Ted
  • kaw74z1
  • kaw74z1's Avatar
  • 0 to 60 in 15 minutes.
Re: just bought a 81'kz1100
17 Jun 2009 21:16 - 17 Jun 2009 21:17
#300089
Hi Ted and welcome to the site :) Your output shaft has to be turning to get your bike to go into 2nd. gear. Sitting still it will only go into 1st. and neutral. Also check here for carb. kits. www.z1enterprises.com/
1974 Z1 with a MKII And a 1105 big bore kit 10.5 to 1 comp. Andrews 2x cams ported head dyna s with green coils V&H sidewinder pipe airshifter 4in.over arm
Last edit: 17 Jun 2009 21:17 by kaw74z1.
  • Tedster
17 Jun 2009 21:30
#300094
thanks
i was really worried at first till 3 or 4 other people replied on the newbie post to.i am really glad to hear that this is gonna be a nice bike once i get it back together
thanks ted
