suggested tire sizes.newbie
  • trickyricky
  • trickyricky's Avatar Topic Author
10 Mar 2008 10:47
#199338
Hey guys im new to kz 1000 . I just got a kz1000 77 and am making into a dragbike. anybody know what size compuond I can get on the back tire. Its the stock 3.5 (?) wire wheel. Im gonna just use stock wheels and swingarm for now but I want a bigger and wider tire. please let me know. thanks guys.
  • mjg15
  • mjg15's Avatar
Re: suggested tire sizes.newbie
10 Mar 2008 11:12
#199344
Stick with the stock size tire on the stock rim . If you put too big of a tire on the narrow rim it just looks dorkish and doesn't work well either .
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
  • trickyricky
10 Mar 2008 11:33
#199346
thanks for the info are you saying that a 110/90/18 is the best choice for the rear wheel. I was just wondering how much larger I could get. I just want the measurement cause I need a new tire also. thanks again. I will be drag racing only but I want to keep the stock look except for the skinny rear tire.
  • StreetfighterKz
  • StreetfighterKz's Avatar
10 Mar 2008 11:49
#199350
If you actually want to get a little more rubber to the road put on a 100/90 or a 100/80 tire. That will flatten out the contact patch a little. If you want to go wider than 120 relace your hub with a wider rim. That's the only way to fully utilize a wider tire.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • mjg15
  • mjg15's Avatar
10 Mar 2008 11:58
#199353
A 120/80-18 should fit fine also .
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
  • StreetfighterKz
10 Mar 2008 12:12
#199357
True, but if he's drag racing only so he wants as flat as a profile as he can get. That's why I recommended the "narrower" tire. It'll stretch to a flatter profile than a 120 will.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • jonnybiker
  • jonnybiker's Avatar
10 Mar 2008 13:54
#199375
You should be able to go to a 130 or perhaps even a 140. Your best bet is to measure everything up and know how much room you have before buying a tire. my 2 cents worth. take care all. jonnybiker
  • trickyricky
10 Mar 2008 18:59
#199443
thanks for all the help guys I will look at the 130 and 140 and the 80 series. I just want a wider tire that will last and I usaually order online and didnt know whatsize to get. also how do you know if you get a z-1 . will it say it on the bike or the title somewhere. again thanks a lot guys.
  • PLUMMEN
  • PLUMMEN's Avatar
10 Mar 2008 22:26
#199468
you can run around a 130 if you want to lace up a 3 1/2"rear rim .put a few short sheetmetal screws around the rim into the bead of rear tire on each side,then you can run lower air pressure to help with hooking up without spinning tire on rim and cutting valve stemB)
  • steell
  • steell's Avatar
11 Mar 2008 09:55
#199531
IIRC, the stock rear rim is a 2.15"
Just a little to skinny for a 130.
