From the U.S. of A.
- xschop
From the U.S. of A.
11 Feb 2008 07:07
Not Uraguay! Hi I am new here, I have designed a bolt on chaindrive for a yamaha xs1100 (factory shaft) and now am searching for a swingarm to go with a kit. I figured the KZ1000 was comparable to rear tire when they came out, so wanted to know the dimensions of a KZ--- swingarm if anyone here knows? Like what is the width between pivot points where it inserts into frame and rear shock mounting distance...any help here would be greatly appreciated. I have put many different front ends and swingarms on different chops. Currently I am putting on a complete Hayabusa front end and a Triumph St single sided swingarm to this bike.....
Re: From the U.S. of A.
11 Feb 2008 08:24
the swingarm measure's nine inches where it fits throught the frame,without the dust caps.
- xschop
11 Feb 2008 08:35
Thank you banshee. That is a go. Do you know the shock mount width on the KZ swingarm. Good to see you are from the Ok!
