Dirty KZ.
- krcrawford29
- Rickman
Re: Dirty KZ.
27 Jan 2008 16:16
I've done pretty good with simple green. put it in one of those pump sprayers like you use for weedkiller. you might need to knock off the heavies with a nylon bristle brush. if you still don't think it looks clean enough, use some steel wool and WD-40. on chrome, you can try aluminum foil and wd-40.
Cheers
Ricky
Cheers
Ricky
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
- Bluemeanie
Re: Dirty KZ.
27 Jan 2008 16:16
Get the engine warm such as riding down to the local self serve car wash. Spray some Gunk, etc, engine cleaner on, let soak if you can for about10 minutes and then use the high pressure wand to remove the crap. Just be careful where you apply pressure on the motor.
Post edited by: Bluemeanie, at: 2008/01/27 19:18
