New 650d in New Mexico
  • Afrosemite
  • Afrosemite's Avatar Topic Author
24 Jan 2008 17:34
#190899
Hey yall, Just got a 78 kz650d sr. I liked it a lot when I test rode it but for some reason I cant get it started now =(
\'78 Kz650d sr
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: New 650d in New Mexico
25 Jan 2008 06:22
#190976
Welcome.
Do post up some pictures of your bike. We love pix!
After checking your spark on all 4 (from other post), check your gas flow (you have gas right?).
You can open the drain screws on the bottom of the carbs a little and see if gas will drip out. If it does, you know your getting gas to each carb.
If no gas is there, (gas petcock/valve on tank is on right?) the petcock may need cleaning, or you may have rust or other debry in the tank.
On a Vacuum type petcock (has two lines on the petcock. one larger gas line and a smaller vacuum line) if the vacuum line is not attached on both ends, gas wont flow.
Post edited by: rstnick, at: 2008/01/25 09:32
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
