My name is roadtrip and i'm a kz holic
- RetroRiceRocketRider
Re: My name is roadtrip and i'm a kz holic
23 Jul 2007 19:36
Not a bad looking project you have there.
It's hard to tell from the angle of the pic, but does the left side (generator) engine cover have 3 mounting bolts/screws, and then another 3 screws closer towards the center near the "Kawasaki" name?
If it doesn't have those 3 inner screws, then your bike is a '78 or newer model.
The right side (ignition) cover isn't original either, but IMHO looks a lot better than the plain cover they came with.
Post edited by: RetroRiceRocketRider, at: 2007/07/23 22:37
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- The Gringo
- ¡Usted no necesita otra motocicleta!
23 Jul 2007 19:54
The front master cylinder is from a 78 or later bike and I can see someone added an electronic ignition from a later model as well.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- rt66roadtrip
23 Jul 2007 21:48
ID sticker on neck says:
9-77
kz650c-011***
eng #kz650be0584**
yes it has a gpz550 ignition and the points cover is one i picked up on ebay.
Original cover was smooth with "KAWASAKI" (all caps.
Dunno about the master cylinder. its frozen so i'm swapping it. shouldnt it be a round one?
She does run. carbs are gummed up and need rejetting for the pod filters. so it idles rough and bogs badly when you gass it.
i want to make her silver again. someone painted her red or put a faded red tank on it?
Post edited by: rt66roadtrip, at: 2007/07/24 00:58
9-77
kz650c-011***
eng #kz650be0584**
- The Gringo
24 Jul 2007 04:05
Being built in 9/77 would make it a 78 model which would explain the master cylinder. If it were a 77 it would have had the round master cylinder. It is possible to rebuild it but if you end up swapping it make sure you get the 5/8 master cylinder that is designed for use with dual discs.
As for making her silver again check with Reborn650 here he has researched the closest paint code and should still have the number.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
