Check out the hole on my bike!
- Pacificmonarch
13 Apr 2007 22:13
Finally got the pictures to come through. Check out this hole. Is it going to interfere with anything? Do you think I can get it fixed?
- Pacificmonarch
- Pacificmonarch
Re: Check out the hole on my bike!
13 Apr 2007 22:15They guy who owned the bike before sort of patched it up with fiberglass.
Post edited by: Pacificmonarch, at: 2007/04/14 01:16
- KZErider
13 Apr 2007 22:21
Man! That's a hole! Someone posted a fix for a similar thing just recently. Don't know if it's tested out OK or not, neither do I know where to search for the thread. I'm sure the guys here will come to your aid.
81 KZ750E2(project), 81 KZ750E2(parts donor), 87 BMW K 75C - got it runnin, didn't care for it, holding for family member, 79 CB650(project) Nomad 1700, VStar 950
- RetroRiceRocketRider
13 Apr 2007 22:38
I'm pretty sure Mark Wing did a repair in the same area on his bike, might want to hit him up for info.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING![:-/ :-/](/irritated.gif)
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- Pterosaur
- Visitor
13 Apr 2007 22:40
Pacificmonarch wrote:
I'm surprised it hasn't interfered already.
I wouldn't go riding too far in the rain, that's for sure.
With the back side of the ignition plate open to the elements like that, all kinds of things can interfere - up to and including small animals.
At some point, it'll be an imperative.
The best fix would be a new set of cases. Period.
There's any of several ideas that might provide *some* level of comfort with a situation like that, but fiberglass wouldn't be high on my list.
I'd hunt around boneyards to see if a junk set of cases could be had on the cheap - with the appropriate section intact.
Depending on your metalworking skills, the existing crater in your cases could be trimmed back to some cleaner shape - and *measurable* dimensions - and a matching section from the junk cases could be cut to fit the trimmed cases and heli-arced into place.
The resultant repair - if done by someone that knows their stuff - could be ground, filed and polished to a degress that it'd do the job - and look acceptable to the casual eye.
Cost-wise? Hard to say. Depends on how much of the job - and required tools/equipment you have at hand.
Who knows - in looking around, you might happen on a complete motor in runnable condition for less than it'd cost to fix that one...
- godsjester71
13 Apr 2007 22:53
JB weld and duct tape should do. How did that happen?
- bigbadwolf76
13 Apr 2007 23:09
Yikes! Note to self: Buy engine guards! ![:P :P](/media/kunena/emoticons/15.png)
That would be a hard one to repair because of the contour. My first thought was to cut a strip of sheet metal and stick it on the inside to serve as a form for something like JB-Weld. Use the JBWeld like bondo or putty and form it into the shape of the case. Then, once the stuff hardens, remove the sheet metal/form piece.
I know aviation mechanics have some metal paste stuff they use for dents and dings in metal, but I haven't used it yet, so maybe I'm just talking out my *ss! But, that's the route I'd go. Good luck!
BTW... how did it happen?
- Pacificmonarch
13 Apr 2007 23:10
when I got the bike, it was like that. It just had fiberglass covering it, but I broke it off.
- jimmybon
14 Apr 2007 04:33
meet the pig, camp bike, designed to carry 3 with beer, and dig holes
the alloy patch is 5mm bullet proof aluminium split to 1.8mm , bashed to submition then silicon glued into position with monul steel rivets.
keeps things nice and dry inside.
this bike i bought for $200 with an engine you can't kill, so better to patch
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
- jimmybon
14 Apr 2007 04:34
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
- jimmybon
14 Apr 2007 04:35
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
