tack cable leaks oil at cylinder head
  • manc262
  • manc262's Avatar Topic Author
18 Mar 2007 21:52
#121447
1980 ltd 1000 the tack cable leakes at the cylinderhead i put new gasgets in but it still leaks
Post edited by: manc262, at: 2007/03/19 01:45
Re: tack cable leaks oil at cylinder head
18 Mar 2007 22:21
#121458
Question, please -- what year and model of bike?
Usually not a "gasket" at all. Generally a special seal around the inside spinning shaft plus an o-ring on the holder fitting into the head. Should not leak even if tach cable is disconnected or missing altogether. :)
  • 77KZ650
  • 77KZ650's Avatar
18 Mar 2007 22:43
#121464
Tach Oil Seal - Fits Kawasaki Z1 KZ550A1/A2/C1/C2 KZ650B/C/D/E1/H1 KZ750E1/E2/H1/H2 KZ900 KZ1000A/B/C1/C1A/C2/C3/D/E/G KZ1300A1-A4/B2
www.z1enterprises.com/detail.aspx?ID=1585
10mm O-Ring - tach drive. Fits Kawasaki KZ750B1/B2/B3/B4/G1/K1/K2/M1 KZ900A4/A5/B1 Z1/A/B ZX750E1/E2
www.z1enterprises.com/detail.aspx?ID=1563
07 MDP Rookie of the Year
