Smaller Cafe Style rear lights without cutting/welding? 17 Apr 2024 06:34 #897721
  • ThatYeti
  • ThatYeti's Avatar Topic Author
  • Thank you received: 10
With the front end cleaned up on my '76 KZ400 I'm wanting to clean up the rear lighting with something a little less bulky and more cafe-esc.  Not a fan of cutting things or making permanent changes to the frame, etc. so I was hoping someone may have come up with a solution that allows me to mount something like an LED light strip for the brake and signal lights while getting rid of all the bulky old lenses.  Ordered a few light strips and can see that they'll all work, but don't have any way to mount them as I believe they're all meant to be stuck to a new rear 'hoop' that's welded on after cutting the last inch or two off the rear of the frame.  Open to any/all ideas, but was sort of imagining like a drop in/bolt on bracket of sorts that would have a space to slip in the led light strip.  Terrible at drawing unfortunately so we're going to have to work on imagination here, but I think about it similar to a weld on rear frame hoop, but one that just bolts into the holes where the rear blinkers are stock and slides into the slots for the rear seat back bar while having a space for the light strip.
Hopefully that's not too confusing but let me know if I can clarify and thanks in advance for any guidance as always.
'76 KZ400
Smaller Cafe Style rear lights without cutting/welding? 17 Apr 2024 07:15 #897726
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 382
I could see why you would want a different set as the KZ400 rear light is remarkably trailer-like.
I have one of these on my cafe bike.  LED Tail Light Brake Rear Lamp For Motorcycle eBike Brake Light Assemblies | eBay
You may have to make a simple bracket adapter if you don't want any new holes.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
The following user(s) said Thank You: Wookie58, ThatYeti
Smaller Cafe Style rear lights without cutting/welding? 17 Apr 2024 08:13 #897732
  • ThatYeti
Thanks and yes exactly my thought, hoping to have it looking less like a rental trailer from behind haha.  Not what I was thinking at all but don't hate this idea.  What did you do for turn signals and the license plate if you went this route? and did you keep the full rear fender? Considering swapping it for a shorter one but not real sure how exactly it comes off, or cutting it down potentially.
Was initially thinking of using something like this to handle both but really don't have any way to mount it without adding a new rear hoop:
www.amazon.com/dp/B07DCW4QRS?psc=1&ref=p...dt_b_product_details
'76 KZ400
Smaller Cafe Style rear lights without cutting/welding? 17 Apr 2024 08:17 #897733
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1955
Could you mount it around the lower edge of the seat pan ?
The following user(s) said Thank You: ThatYeti
Smaller Cafe Style rear lights without cutting/welding? 17 Apr 2024 08:32 #897735
  • ThatYeti
Don't think it sticks out past the end of the seat so don't think that's an option unfortunately
'76 KZ400
Last edit: by ThatYeti.
Smaller Cafe Style rear lights without cutting/welding? 17 Apr 2024 08:36 #897737
  • ThatYeti
​Pics for reference on the current setup (please excuse tight garage space/terrible pics)
'76 KZ400
Smaller Cafe Style rear lights without cutting/welding? 17 Apr 2024 09:03 #897738
  • ThatGPzGuy
This is one I ran before I did a rear fender delete. It includes a license plate bracket.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Smaller Cafe Style rear lights without cutting/welding? 17 Apr 2024 09:47 #897741
  • Nerdy
  • Nerdy's Avatar
  • Thank you received: 390
I did a rear fender delete on a KZ400 and installed one of these:
Note that these are only tail/brake lights; they are not turn signals. Both are on when the bike is running and both brighten when the brakes are applied. And I mean BRIGHTEN.
For the turn signals I made 90-degree brackets that attach to the taillight frame via the upper license plate bolts. This puts the signals at the rear of the bike and ensures there's a little bit of distance between them. I used K&S incandescent turn signals, which are also very bright.
Edit: forgot to mention that the bottoms of the taillights are clear and serve as the license plate light, as you can see in the pic.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Last edit: by Nerdy.
Smaller Cafe Style rear lights without cutting/welding? 17 Apr 2024 10:00 #897742
  • ThatYeti
Thanks, that might work. Do you have any pics of the rear fender delete?
'76 KZ400
Smaller Cafe Style rear lights without cutting/welding? 17 Apr 2024 10:15 #897744
  • Wookie58
  • Wookie58's Avatar
  • Moderator
What I had in mind was a piece of sheet metal or plastic sheet bent to the shape of the seat (pink line) mounted to the bottom of the seat pan then the LED mounted in the new piece (green line)
Smaller Cafe Style rear lights without cutting/welding? 17 Apr 2024 10:16 #897745
  • ThatYeti
Exactly what I'd had in mind as well, and it could use the existing holes for the signals to mount. Was just hoping someone else might have already made one either out of metal or 3D printed, etc.
'76 KZ400
Smaller Cafe Style rear lights without cutting/welding? 17 Apr 2024 10:20 #897746
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Depending on your fab skills it could be a really nice piece
