  • Page:
  • 1
Engine Paint Removal 27 Oct 2023 07:18 #891013
  • Deon
  • Deon's Avatar Topic Author
  • 1964/07/20
  • Thank you received: 4
Hello, i would like to remove the old paint and clean the engine which does not look too good at the moment. I would like to do this without removing and stripping down the whole engine. Can anyone recommend a good engine paint remover. I did see a post that said Strypeeze was very good but dont seem to be able to find anyone selling it at the moment.
Any help appreciated.
Hello from the UK
NC750X
KZ650E1
Engine Paint Removal 27 Oct 2023 07:38 #891014
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1955
You may find it tricky to use paint stripper on the engine while it is installed without stripping paint from the surrounding area that you don't want to remove
The following user(s) said Thank You: slmjim+Z1BEBE
Engine Paint Removal 27 Oct 2023 08:45 #891016
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 523
Don't do it!
There is only 1 way to do it right.  disassemble & vapor blast or glass bead bare engine.
Maybe a portable vapor hone with baking soda kit from the Chi-Comm Tool Store by the Harbor?
And... Today there are no good chemicals for stripping paint! Unless your doing an HGTV project, stripping the latex paint off your wood moldings!
What you want to do? High Pressure Washer! Good degreaser! Scrub with Scotch pads & Brass Brushes! Compressed air! THEN REPEAT! Spray it down with fresh acetone or lacquer thinner, let flash off, more compressed air. Then spray away.
Should be able to keep the spray bomb paint on it for awhile!
The following user(s) said Thank You: sf4t7, hardrockminer, Wookie58, Deon
  • Page:
  • 1
