  • Page:
  • 1
Does anyone know of A wider triple tree that would hold KZ forks? 26 Apr 2024 08:26 #898133
  • clagrow68
  • clagrow68's Avatar Topic Author
  • Thank you received: 0
Looking to space apart the distance of the front forks to accept a wider (ZX6E) front wheel.  Does anyone know if there is a triple tree\stem setup that is wider apart that will hold the stock forks? (And , for the record, I do realize I can swap the entire front end to a ZX^).  Just would like to keep my front stock forks.
1982 Kawasaki KZ1000
Does anyone know of A wider triple tree that would hold KZ forks? 26 Apr 2024 12:14 #898139
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1834
If you can find a set with the spacing you want but intended for thicker forks you can sleeve the trees with "split bushes"
Does anyone know of A wider triple tree that would hold KZ forks? 26 Apr 2024 13:09 #898141
  • Stereordinary
  • Stereordinary's Avatar
  • Thank you received: 134
What’s the diameter of the fork tubes you’re trying to keep/use?
A breeze from the west.
‘90 ZR550 Zephyr (x2)
Does anyone know of A wider triple tree that would hold KZ forks? 26 Apr 2024 13:14 #898142
  • Moose1800
  • Moose1800's Avatar
  • Thank you received: 260
I’m not positive but I think the early police bikes had wider triple tree, I know they had a wider front tire/wheel.
The following user(s) said Thank You: sf4t7, clagrow68
Last edit: by Moose1800.
Does anyone know of A wider triple tree that would hold KZ forks? 26 Apr 2024 13:45 #898145
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Also don't forget if you "mix and match" wheels and forks there will probably be other challenges to overcome such as speedo Drive, brake spacing, headlamp mounts etc
Does anyone know of A wider triple tree that would hold KZ forks? 26 Apr 2024 20:01 #898149
  • clagrow68
They are stock KZ1000, so 38mm.  They are freshly chromed and in excellent shape.  Would just like to run a wider front wheel that matches the rear I'm going to use.
Does anyone know of A wider triple tree that would hold KZ forks? 26 Apr 2024 20:02 #898150
  • clagrow68
Thanks Wookie, Yeah I realize the other challenges that will arise.  Still in the planning stages.
Does anyone know of A wider triple tree that would hold KZ forks? 27 Apr 2024 00:37 #898155
  • Wookie58
  • Wookie58's Avatar
  • Moderator
What is your current spacing ?
  • Page:
  • 1
