  • Page:
  • 1
Center stand compatibility for 82 KZ1000 LTD (K2) 23 Apr 2024 19:02 #898039
  • Pachyderm
  • Pachyderm's Avatar Topic Author
  • Thank you received: 5
My research on the Partzilla catalog indicates that the 1982 KZ1000 LTD (K2) center stand was only used in 1981 and 1982.  Finding the right one so far has been challenging.  Do any of the other KZ1000 center stands fit, even with minor modification?
Thanks for your consideration.
Todd
Center stand compatibility for 82 KZ1000 LTD (K2) 01 May 2024 15:32 #898313
  • Suazo
  • Suazo's Avatar
  • Thank you received: 2
I checked the PN on the partzilla page for the 1982 KZ1000 LTD (K2) and cross-referenced it with the one for "1982 LTD" on the Kawasaki Owner Center and the PN's match. Then I looked at the CSR - KZ1000-M2 on Partzilla and that has the same PN: 34011-1038. Based on that, a centerstand for an '82 CSR 1000 appears to be the same.
And there's currently one of those being offered for the CSR on EBay
Bolts and springs... I dunno about availability. G'luck!
All "I Am Not An Expert" etc. disclaimers apply.
The following user(s) said Thank You: Pachyderm
Center stand compatibility for 82 KZ1000 LTD (K2) 01 May 2024 15:52 #898315
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2111
A whole lot of models used the same pivot bolts, including the whole P series and the 1981/82 J an GPz. Those bikes all use the same stand, but it has a different part number than the K and M. It is altogether possible that the differences are minor. Perhaps some folks here could offer up some measurements.
Center stand compatibility for 82 KZ1000 LTD (K2) 03 May 2024 20:36 #898422
  • Pachyderm
Thanks for your input, folks.  Patience paid off.  Scored one on Ebay and found the bolt set there as well.
Todd
  • Page:
  • 1
