USD Forks 11 Dec 2023 12:36 #892609
  • Stereordinary
  • Stereordinary's Avatar
  • Thank you received: 134
As a regular contributor to the forum I see no issue with you reaching out to share the cost of this project.
Thank you!
I assume a chunk of the cost is to write the CNC programmes ? have you thought about reaching out with a separate post to the membership (it's possible that one of the many engineers on the forum may possess the skills to write the programme and be prepared to help you out?)
I'm not sure what's the major cost, if it's a conversion from my file to a CAM program, or the materials and labor, etc. What I do know is that there are a couple of websites (including Xometry, and Cognito Moto) that I can upload my files and they provide an instant quote. I used Xometry to have the axle spacers made, but I'd love to be able to go with Cognito Moto for the triple trees, as they are US-based, already have familiarity with motorcycle triples, and their price for multiple units is actually better than Xometry. As far as help from members here is concerned, I'll take all that I can get, and hopefully there's some interest once I post up a thread in the for sale section.[/quote]
With regards joining the two parts of the top yolk, you could consider the below...
I have certainly considered your idea here, and am still looking at it as a potential option. The only drawback I can see is that if I want to disassemble various parts involved later, pulling the bolts out will loosen the mounting of other components that wouldn't otherwise be loose. It could make some operations more complicated than they would be otherwise.
The right adhesive would be plenty strong enough to hold the instrument cluster... the cost of such high tech adhesive may be prohibitive.
I can get West System epoxy from my local marine supplies store, and was thinking that might be sufficient. If not, I'm curious what would be a good choice. Perhaps a polyurethane glue? I wouldn't need a lot of it, so a small quantity might make it affordable.
By the way, have you reached out to PDM Custom Fabrication?
I found their email address, but haven't reached out yet. Not quite sure what to ask exactly, but perhaps I should get the conversation started.
A breeze from the west.
‘90 ZR550 Zephyr (x2)
USD Forks 11 Dec 2023 14:20 #892614
  • Buzz Nichols
  • Buzz Nichols's Avatar
  • Thank you received: 105
Based on my experience with them, I can add a couple more good reasons to go with Cognito. Their customer service is easy and attentive, and they make absolutely beautiful stuff.
1978 KZ1000 LTD
The following user(s) said Thank You: Stereordinary
USD Forks 28 Feb 2024 20:41 #895730
  • Stereordinary
Fork extensions for the damper rod.
Male thread at one end to screw into the damper,  female at the other to take the cap head bolt at the bottom of the leg , drilled through for the passage of the damping fluid and flats milled either side to take a spanner.
Aaaaand, we're back! I was thinking about using zed1015's method here for getting that extra 20mm's out of my forks. Looking at info and videos about fork disassembly (including the FSM for the forks I have) they all show starting at the top, but I have heard there is a method where you start at the bottom. Supposedly removing the large bolt at the bottom of the fork is a lot easier when you have the spring compressing the assembly. But then one source said something about that bolt breaking easily, which I can't imagine a bolt that large just snapping. So I'm trying to make sense of it all. Is there any reason why I couldn't start with the bolt at the bottom, and once that's removed, pull the cap off the top? The whole cartridge should come out as one piece right? Then I could add the extension piece at the bottom like zed did, and reassemble. I guess there's a question of getting the torque on that bolt right after reassembly, but wouldn't it be accurate if done with the fork bottom held steady in a vise?
Also zed, you mentioned drilling it through for passage of fluid, but I can't tell from your photos where. All the way through the center I guess? If it's just taking the place of the bottom bolt, which then threads into it, why does it need that passageway?
Last edit: by Stereordinary.
USD Forks 28 Feb 2024 23:59 #895731
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1897
There is a special tool to hold the internals once the spring is removed, this will also hold it while you torque the bottom bolt on reassembly. Torque spec will be in the FSM as will the number for the holding tool (they aren't crazy expensive)
USD Forks 29 Feb 2024 02:25 #895734
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1480
Yes! On forks with rebound damping the bottom bolt also resembles a banjo bolt which allows fork oil to pass through.
The extension also needs drilling through lengthways to allow a continuation of that passage.
USD Forks 24 Mar 2024 08:53 #896836
  • Stereordinary
Just thought I’d update where I’m at with this project. I was busy with other things for a while, and waiting to hear back from Cognito Moto. But I’ve had a little bit more free time, and a bike in my shed for other service, so I am turning my focus back to it.
I decided to revisit Wookie’s suggestion of moving the forks in closer together to eliminate the need for any kind of rotor spacer. I had previously assumed that it would be too difficult to take the wheel in and out for tire changes. But then I thought, well how difficult are we talking, and is it still doable? So I moved the clamps in, making the fork-to-fork spacing 200mm.
It works, and it doesn’t. In order for the calipers to center on the rotors, I still need to move each fork an additional 2mm in. Also, the largest section of the fork (where the lower triple clamps) is now touching the headlight bracket, and causing it to flex inward a little. The good news however, is that the wheel is actually very easy to get in and out because the right side spacer now just fits through the lower fork clamp.
For the next revision I want to try moving the forks in that extra 2mm, but I also want to see if I can reduce the offset a little. This will do a few things, correcting the overall geometry, moving them away from the headlight bracket, and closing the gap between them and the fuel tank while turning full lock. Will keep y’all updated.
USD Forks 24 Mar 2024 21:30 #896858
  • Stereordinary
With all of this narrowing of the fork spacing (5+2=7 each side) I'm looking at the spacers that are needed to adapt the ZX6R forks to the Zephyr axle.
Quick recap, for those not caught up on this thread: We previously discussed changing the bearings to fit the ZX6R axle into the stock Zephyr wheel, and/or having the Zephyr wheel milled out to accept a ZX6R bearing. However I've just hit nothing but brick walls with both of those ideas. Bearing manufacturers don't want to say their bearings are sufficient for the job, and no one seems to want to mill a wheel (if there even is enough space). Plus there's the added complication of my preference for using the stock speedo drive. So unless some other answer comes up on those topics, I'm going to be making axle spacers.
Here is a screen grab of what the spacers look like (in yellow):
The fork lower is represented in a gold/orange color, and the Zephyr axle is the light purple.
My concern with this is that the spacer needs to be shorter than the total width of the fork lower by 7mm. A few mils and I probably wouldn't worry about it, but as you can see, it's sort of floating above one of the fork lower pinch bolts. I could make it the full length, but then I'd need to also make a separate inner spacer instead of using the stock one, and I highly doubt it would work at all like that on the other side where the speedo drive is.
So the question is whether or not it's ok to set it up like this. That inner fork lower pinch bolt is only clamping against so much material, but maybe that's ok? It does sit over the centerline of the bolt. Maybe I need to design a new inner spacer, and maybe the speedo drive can be modified? If it was milled flat on it's left-most side... (hard to explain in words)?
USD Forks 25 Mar 2024 13:39 #896878
  • Stereordinary
Just did a speedo drive test fit. It was looking like there was no way the cable would fit around this fat Nissin caliper, so I decided to take a gamble and modify the drive itself. I thought that might be a smarter idea than trying to modify the fork lower. Basically all I did was remove the two notches on the drive that are there to help stabilize it in the stock fork lower. By the looks of it, with the cable attachment part angling outwards, and the brake caliper radial mounts angling inwards, they might overlap, which would stabilize the drive. Pretty pleased to report that it works. Unless anyone can see any reason why this is a bad idea, I've got it mounted in a functional manner.
USD Forks 17 Apr 2024 19:32 #897767
  • Stereordinary
I would love some feedback on the posts above. Pretty please?
I'm not an engineer, and I genuinely don't know if I'm creating a problem with this narrow spacing concept. The centerline of the forks is only about 0.75mm inside the centerline of the axle collars, so I feel like that's probably not a huge deal. But is it? Should I go back to the wider spacing and just shim the rotors?
