  • Page:
  • 1
How to charge a 6v battery? 01 Apr 2024 11:04 #897139
  • ckahleer
  • ckahleer's Avatar Topic Author
  • Thank you received: 140
I have 2 12V smart chargers and a 50 year old 6amp dumb charger that has a 6v/12v switch. Is it safe to use this old charger on  a ke100 6 v battery?
94 KE100
81 CM200t
82 KZ305
85 VT 500c
85 VF1100c
How to charge a 6v battery? 01 Apr 2024 11:09 #897141
  • Moose1800
  • Moose1800's Avatar
  • Thank you received: 261
Yes on the 6 volt charger but 6 amps is a bit much for a small battery just don’t leave it on very long.
How to charge a 6v battery? 01 Apr 2024 11:42 #897142
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 384
Here is some info on making and using a DIY charger. I can say it works well and will charge just about any voltage battery.
www.alpharubicon.com/elect/3dollarbattggn.htm
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
How to charge a 6v battery? 01 Apr 2024 12:17 #897144
  • F64
  • F64's Avatar
  • 81-KZ440D2
  • Thank you received: 357
You can get a voltage regulator for about $30.
www.amazon.com/DROK-Converter-Adjustable...0BQBXMH67?th=1&psc=1
Hook it up to your 6 volt or 12 charger.
You can control the voltage down to about 0.5v dc.
Plus you contol the current.
I just hooked my regulator up to a laptop charger to charge my 12v battery.
Battery University has a lot of info on charging batteries.
batteryuniversity.com/article/bu-405-cha...-with-a-power-supply
81-KZ440-D2.
LIC, NY
Last edit: by F64. Reason: because half my brain fell out onto the floor
  • Page:
  • 1
